Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Black soot on plastic in dishwasher
I washed a load as normal and now have all plastic items as well as the dishwasher tub coated in a black soot. Does anyone know what this is? Is it a broken charcoal filter or something and how do I fix it?
    New Friend:
Seems to be the rubber on the seals melting. I'm trying to replace the rubber gasket on the bottom around the sump.. I can't get the new gasket and assmbly to fit into the pit. Guess it's time for a new washer.
Posted on May 25, 2013
  • 1 more comment
  • shane May 25, 2013
    Oh ... and by the way .... it's a 4 year old Maytag dishwasher. My 4 year old Maytag microwave broke, too. My 2 year old maytag oven broke. My 1 year old Maytag dryer broke. My 4 year old Maytag clothes washer operates poorly. Moral of the story ... DON'T BUY Maytag/Whirlpool!!
    Seems to be pretty glaring evidence that Maytag and Whirlpool(same company) make poor quality products.
  • 93 Answers
You can get a product called dishwasher majic. It is used to clean the tub of a dishwasher. Big box stores (LOWES, HOME DEPOT) should have it. There is not charcoal in the unit. I suspect is grease from the rubber seal around sump assembly.
Posted on Jul 24, 2008
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Everything in and outside our fridge is getting a black soot on it?
This sounds dangerous, I suggest you hire a pro to look into this.
Nov 21, 2017 | LG LFX25971ST Bottom Freezer French Door...
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Have cleaned rotary arms etc but still getting black specks insie cups and glasses. Is it safe to use a small amount of baking powdwer in the machine and then run it through a washing cycle (empty)?
Yes, you can use baking soda, I use it at work especially on the models with plastic tubs.
The black specks may be rust or a shutoff valve that is failing. (The water supply lines).
Jul 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Kenmore Washing Machine-front loader
There is a small gap between the metal basket and the plastic tub. Small items - especially small socks and silky clothing can slip through to reach the pump. Wash these items in a mesh laundry bag.
This is a "normal" characteristic of all front load machines. Only a Maytag Neptune positively addresses this issue. They have a long, thin, fine brush between the basket and tub which consistently prevents this issue in their machines.
Mar 10, 2008 | Washing Machines
Black spots on plastic items
I have the same problem on my Bosch dishwasher Model # SHX33A05UC. It is about 6 years old. I have replaced three gaskets and it did not solve the problem. I am a 25 year mechanical engineer. I do not recommend anyone changing these gaskets on their own except for the long dishwasher door gasket (which goes along the top, left and right door edges) which is quite easy to replace. The other two gaskets, which were quite difficult to replace, were the gasket at the bottom of the dishwasher door and the sump pump gasket. I am still having the tar like black tiny dots depositing on my plastic tupper wear on the second shelf. I will likely not buy a Bosch dishwasher ever again. I will make my decision after hearing what Bosch tech support has to say about what I need to replace next. Could it be the rubber drain check valve not operating correctly? I need to find out. I have spent so much time trying to solve this black tar dot problem!!!
Feb 11, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
529 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
