Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Rear Projector TN
Recently while using a WII on our TV it went to a blank screen with the words no signal. Now we can't get picture or sound. You can go to the menu section and work there but nothing seems to help. We do use Direct TV and have it set to Video 1, DVD on Video 3 and VCR on Video 4. I have no clue what is wrong can you help?
  • sheliainstru Jul 23, 2008
    We have already tried the hard reset, no change at all. Thanks
    President:
  • 1,952 Answers
It may be picture tube fault...replace tat and use
Posted on Sep 14, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
    else
    sounds like the convergance IC's. They will need to be replaced.
    Master:
  • 382 Answers
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Posted on Jul 23, 2008
  • Natesan Sabesan
    Natesan Sabesan Jul 23, 2008
    Well Then try to post the problem in this forum,where i will guarentee you can get a 100% required solution..This is especially for sony products..Please check it out..
    http://www.agoraquest.com
    Thank you!!...
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Picture went out (completely
Your Sony TV needs Screen (G2) volts adjustment and I'm not sure that you can do that or not by yourself.
If you are confident and know electronic stuff repair, then let me know to guide you OR call local TV tech to perform adjustment.
Thanks.
Oct 30, 2009 | Televison & Video
I have a Rear Video Projector model # KP-46WT510 and it started acting up. It is a double picture when we try to watch TV. Can this be easily fixed?
Unfortunately it is a job that will require an experienced TV technician,
You have 2 large 18 pin ICs called convergence amplifiers who's job is to insure beam alignment of the three picture tubes in your TV set (Red, Green & Blue). One of the 2 chips have shorted and more than likely cause damage to the 2nd one as well. This involves removing the board where the ICs are mounted then rmoving the ICs by a process called desoldering & resoldering during the replacement process. They are not a plug in Ics.
Hope this helps.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Kp-46wt510 rear projector
Have you tried adjusting the red screen control located inside the front of the set? Usually behind the speaker grill. It is part of whatis called the control focus/screen block. There are 6 controls on this assembly. Be extremely careful high voltage is present. If you turn the red screen control and no red is seen onthe red gun , there are two possibilities. A) bad picture tube B)open filament connection on crt board. Scrivitron
Jun 04, 2007 | Sony KV-27V22 TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
