A red light keeps blinking tv wont turn on. - Televison & Video
  • 8,617 Answers
I will need the model number of your set, and also how many times it blinks in between a pause if a pause is present as that could be a error code. Please reply to this same post.
Posted on Jul 23, 2008
  • Sonny Berry
    Sonny Berry Jul 23, 2008
    I am not getting any information on that model number, can you post what brand the TV is? thanks
  • Sonny Berry
    Your set has whats called a reset generator CHIP ( Q840 ) and A diode D841 which supplies the 5volt to the reset generator. Check that diode out of circuit with a ohms meter it should have continuity in one direction and no continuity when you reversre meter lead polarity.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
