Question about Tag Heuer 2000 Exclusive Qtz WN1353.BD0342 Wrist Watch
Tag Heuer crown fitting.
Crown came of while re setting. spring was exsposed so i took it out for safty. How do i put crown back on.
  • affinity Jul 23, 2008
    crown came off of a Tag Heuer WN1353 while re setting. spring was exsposed so i took it out for safty. How do i put crown back on.
    Genius:
  • 2,028 Answers
If you want to do this yourself, you will have to take the watch apart. There is an extremely small retaining clip that holds this in place. It may be floating around in the watch somewhere or it may have fallen out. You will need this to get the crown back in place. Once you have the back of the watch off and found the clip, slide the crown and spring back into place and you will see where the retainer goes. Personally, I would recommend taking it to a certified technician to have this done. The parts are extremely small and can be bent or broken very easily rendering the watch useless.
Posted on Jul 23, 2008
    Genius:
  • 3,422 Answers
You will have to get this repaired.Please contact the Main support number(866) 260-0460 and they will let you know the nearest service center in your area.
  • Priya darshan Jul 23, 2008
    please dont forget to rate the solution.
    Genius:
  • 1,847 Answers
    Master:
  • 382 Answers
Tag Heuer needs a lot of care and attention while repairing or servicing it so i would kindly advise you to take a Service person who has experience working with the watches..Please dont move ahead on your own rather which is Not advisable!!..Thank you..
Regards!!..
How do I set the time on a professional tag heuer ladies watch
You have to unscrew the crown once it is unscrewed can you pull it out once for the day and twice for your time. Be sure to screw the crown back in when you're finished or else you'll get moisture inside.
Mar 05, 2015 | Tag Heuer Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    I cant set the time.
    does it have screw down crown if so you need to unscrew it anti clockwise once you do this you can set time etc if it does have screw down crown remember to scew it back its spring loaded so you need a little pressure if you dont it wont be water resistant..
    Mar 26, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
    How can i make the date of my tag heuer formula 1 change automaticaly?
    To s e t t h e t i m e a n d d a t e
    Your TAG Heuer chronograph is fitted
    with a screw-in crown and safety seals
    which guarantee it to be waterproof
    to 200 m (660 ft).
    Position 0: Crown is screwed in
    (normal position).
    Important: The crown must be
    screwed in correctly to guarantee
    the water-resistance of the watch.
    Position 1: Crown unscrewed.
    To change the hour (change of time
    zone) or date quickly, unscrew the
    crown, pull it out to position 2 (quick
    corrector) and turn it in either
    direction. This mode allows you to
    change the hour and the date without
    any loss of minutes.
    The date changes each time the
    hour-hand passes midnight.
    To set the time, unscrew the crown,
    pull it out to position 3 (setting the
    time) and turn it in either direction.
    After setting the date or the
    time, push the crown back and
    screw in to position 0.
    Oct 10, 2009 | Tag Heuer Formula One
    Sport tag h cant set time
    The crown is lock that's why you cant pull the crown to set.The crown has a thread that lock, you must winding it clockwise to unthread it, so you can set the time..
    Regards:
    VOTIT
    Dont forget to rate:
    Jul 02, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
    Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
    Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
    Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
    I can't seem to set the time on my used tag heuer watch
    Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
    After setting the time don't forget to screw the crown back- it is for water resistance.
    If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
    PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
    Don't forget to rate, please.
    Jan 10, 2009 | Tag Heuer Watches
    Tag Heuer Button Popping Out
    If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
    If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
    Find your nearest watchmaker as both need professional repair and parts.
    Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
    Help setting the time
    Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
    Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Tag Heuer 2000 Exclusive Qtz WN1353.BD0342 Wrist Watch Logo
    234 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
