Question about Weather King 10PJA2501AH Air Conditioner
Check T-stat? Maybee, Check the t-stat on the air conditioner? I have alreadt checked the circuit breaker, should I flip it on and off again?. Thank you for your help
  • 41 Answers
Yes make sure it go's all the way off then click's in the on position dan
Posted on Jul 23, 2008
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
I have a question about a Carrier Air conditioner. It's an outside unit and it's old. When I turn the air on the air blows from the inside heater/air unit upstairs in the wall. Outside the air con ...
Could be just a blown fuse or circuit breaker. Fuses are generally located close to the unit in a small box on the side of the house. You will have to flip the box open to find the fuses. It may have a cartridge you have to pull out. Fuses are not visibly bad, you have to check them with an ohm meter or sometimes a hardware store can check them for you. Otherwise you will have to buy two and just replace them both.
The circuit breakers are usually in the house along with all the other breakers in a main panel. There will be two breakers and will probably be visibly tripped. Just flip them all the way back and forward to reset
Aug 03, 2011 | Goodman CKL49AR49 Air Conditioner
My coleman Mach Rv air conditioner with built in heat strip keeps tripping it's internal circuit breaker when running for any length of time. Just replaced heat strip with new one experienced same issue. I...
There should be an overload protection device in series with the low voltage wiring(t-stat wiring) Is it resting on the heat strip or too close to it? It is a saftey device to shut off the heat strips if the fan quits or a fire in the heat strip section. check that or by pass it, if it stays running then ur thermal protector is bad, couple bucks at the parts house.
Nov 06, 2010 | Coleman Mach III Air Conditioner
How do I turn on the circuit breaker on my goodman ac? The smarter Tec flipped the circuit breaker. Do I turn it or push it?
If it is the breaker box in your house, then just push it to the side so it is lined up with the other breakers in the box. Actually any breaker will be like that. If it is the disconnect outside then it pulls out and you flip it over and put it back in.
Sep 02, 2010 | Goodman CKL49AR49 Air Conditioner
Not getting colling in ducting
go outside to the condensing unit there are two copper lines going into the bottom of the unit one small 3/8" line usually bare and the other 3/4-1&1/4" the small line should be warm or hot to the touch and the large insulated line should be could and have a sweat where it goes into the unit. If the large line is frozen you are low on freon and there is a block of ice in the evaporator unit. if it is warm you again have a problem. In either case you will need an EPA certified technician to recharge the unit. If you go outside and nothing is running the check your breaker first. If O.K. then within three feet of the unit is a power disconnect that will either have a pull out handle with slow blow fuses or a breaker if fuses re-place the fuses if a breaker flip the breaker. Then go in and turn your stat to cool. As a safety device there is a three second delay from when you turn on the stat until the a/c starts. MAKE SURE BREAKER IS OF BEFORE CHANGING FUSES. AN A/C HAS 240 VOLTS and between 30-60 amps CAN kill you. However if you use caution you will be O.K.
Apr 15, 2010 | Carrier 38CKC036 Air Conditioner
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
Aug 09, 2009 | Dometic 57915531 Air Conditioner
I just moved into a brand new home that has cental air (Goodman air conditoner) how do I turn on?
turn the thermostat to cool and turn the temperature down if it still doesn"t run check for double pole breakers that are off
Jun 30, 2009 | Goodman CKL60AR60 Air Conditioner
A/c won't shut off have to use breaker
sounds like your run capacitor has failed you can find it if you remove the top cover there is a side acess were there is a lot of wires coming out remove that acess there should be 3 capacitors 1 fan 1 start 1 run make sure to turn the braker off before checking the capicitors remove the run capicitor & check for shorts
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Dec 09, 2008 | Bryant 462AJC021BA Air Conditioner
Weather King 10PJA2501AH Air Conditioner Logo
43 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
