Question about Dell W2306C 23 in. HD-Ready LCD Television
Set won't come on.
The set has a blue light that comes on. The audio pops.
  • Dell Master
  • 1,183 Answers
Follow the self help troubleshooting steps on the following link.
http://tinyurl.com/6hphkl
Thanks
proton
Posted on Jul 23, 2008
My flash won't pop up.
Theres a button on the side of the camera with a lighting bolt on it push to open leave lens cap on to test then go to menu look for flash/ bracketing and set to open
Dec 19, 2012 | Nikon D60 Digital Camera
Troubleshooting for maxent mx-42hpt51
hello!
Blue screen(bright blue) indicates an absence of signal. If you have "on screen" display characters: menu, channel ##, volume bar, etc, your set might be configured for digital antenna settings, or DTV, "air" mode. Then, you won't be able to get cable channels through. If your "blue screen" is dim and there is no any characters, then your Y-sustain module is bad. Especially, if you have encountered loud "pop" shortly before "blue screen" appeared. Then, it's a major repair with board(s?) replacement. If you can handle that, get back to me in a next session. I will guide yourself "how to".
Thanks,
Alex.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
Television won't turn on. I am getting no power and the blue light doesn't come on and there is no audio either
If there is no click or lights on the front you may have a blown fuse. And usually but not always there is a reason the fuse blew which could be a short in the power supply. If it is an LCD you might have some bulged capacitors in the power suppy which would not allow startup of supply voltages. Get your model number off the back of the set and do a search on Ebay for the power supply and be sure you match the part numbers!
May 20, 2011 | Televison & Video
The blue power light flashes and you can hear a popping sound but no picture or audio
I hook up another set of speakers to my tv that was connected to a amp.when we turn on the amp it blew something we could smell something burning it the tv
Jul 03, 2010 | JVC AV-48WP30 48" Rear Projection...
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
The light comes on a poping sound occurs the light goes back off. The set never comes on. the light come on again and and immediatly shuts off
Sounds like a Arcing CRT tube(s)!, You may have a bad color tube!, Set has one red,blue & green tube. If ones at fault, And you heard a POP - more then likely a BAD CRT, The Set is Turning Itself OFF to prevent any more Damage!.... onegeo
Jul 07, 2009 | Televison & Video
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
HDTV-AT&T UVERSE
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Dell W2306C 23 in. HD-Ready LCD Television Logo
61 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
