Question about Microsoft Windows XP Home Edition
Error accessing the registry
When I run a registry program to add something to the registry I get the message: Error accessing the registry. What to do?
Thanks,
Rod
  • 1 more comment
  • Gauravani Jul 23, 2008
    Yes I am logged in as administrator.
    I do not know if this is related, but I also cannot delete files from my boot drive, but I can from by secondary drive. I can move some of the files, but not delete them.
    Thanks,
    Gauravani
  • Richard Finch May 11, 2010
    There is a bad dose of Virtumondo going around that removes adminstrator privilegdes.
    What antivirus and antispyware scanners do you use?
    Are you logged in as the Administrator?
Access registry:
goto google and search for "unhookexec.inf", u will get the download from symantec website. download it on your desktop, right click on the unhook icon and click 'install'.
now goto run and type regedit, u should be able to access registry.
Posted on Jul 24, 2008
She gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
Upon startup of Outlook I get this error message. The add-in "symantec antivirus Outlook Protection" C:\Program Files\common files\Symantec Shared\vpmsece.dell cannot be loaded and has been disabled by...
http://us.norton.com/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN&ln=en_US
Run this uninstaller from Norton's that should fix the problem Norton's is a terrible program it basically takes control of you system. also check for reg errors i use advanced system care it is available also for free at major geek
Oct 21, 2010 | Microsoft Office Professional 2007 Full...
Error1606
These are the fixes for that error that I am familiar with...The first one usually does it.
Click on “Start-Run, type “regedit” (without the quotes) Navigate to this registry path:
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
Clear the key: Recent (right mouse click on the key/folder, choose “Delete”) Close the Registry Editor and restart the computer.
Or …. “Error 1606. Could Not Access Network Location <Common Administrative Tools>.All Users\'' Error Message When You Install a Program”
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q315352
Or….”Error Message When You Install Plus! for Windows XP: ''Error 1606. Could Not Access Network Location''
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q307683
From (Grif Thomas)
Feb 03, 2010 | HP PC Desktop
Why does the Pc freeze up frequently and slow connecting to web?
try updating all your drivers. email me if you need more help. james06_18@msn.com James...
Sep 09, 2009 | Dell Dimension 4700C PC Desktop
HP Deskjet D2360
First, try running the installation as Administrator. Right click on the executable and select Run as Administrator. If that doesn't work, go to that registry entry and make sure that System and Administrators have Full Permissions.
Mar 26, 2017 | HP Deskjet D2360 InkJet Printer
M3plugin.dll
progra-1maywebs/bar/8.bin/mwbar and 8.bin/m3plugin.dll .may problem with computer
Jun 02, 2008 | Intel Motherboard
Lavasoft adaware problem
Are all you icons at the desktop also gone and are now links but will not open?
If yes pls post back that we can provide you with the solution.
Kind regards.
Feb 13, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
