SA-HT640 I always get an error code F61 when I try to turn it on. My speakers and connections are ok. What can I do? Thanks, Alberto. tecni_fireelectronics@hotmail.com
  • 1 more comment
  • Chris Bothwell Jul 25, 2008
    Panasonic SA-HT640 surround sound dvd player displays F61 code and powers off after less than a year use.
  • canobiusbass Sep 05, 2008
    the F61 thing appears right after i turn on the dvd player and then shuts off
  • Anonymous Nov 16, 2008
    I have samwe problem - Unit turns off after a few minutes or sometimes longer. It used to give an error code now I don't even get that.
I had the same problem and when I talked to the Panasonic Tech they told me to check my speaker connections and once I convinced them that I have not touched the connections since I originally connected the speakers. they then told me that it was a power supply fault and I needed to take it to a dealer. I did a little research and found that the cooling fan was not working, which is another reason for the F61 fault. Check to make sure your fan is running. If not, it is very easy to replace, two screws and one connection.
Posted on Nov 25, 2008
Error code f61 on my panasonic sa/ht930, Kindly advise on these, Thanks.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 06, 2011 | Panasonic sa-ht930 Home Theater Audio...
Hi. I have a panasonic SA-PT860 dvd theatre system. Everytime you turn the on/off button it states that I have an F61 fault. I have looked in the manual and it says to check speaker connections. I have...
- Is your system playing in spite of this error?
Assuming that this is the model complete with "receiver" and speakers+sub and you use these and the original connections. You could try and measure your ohm level on each speaker to control if there is a bad/blown speaker. The Ohm level should be the same on each speaker - roughly.
- Hope this will get you somewhere!
Jan 28, 2011 | Audio Players & Recorders
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
Im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
Jan 24, 2009 | Audio Players & Recorders
Panasonic stereo SA-PM28 displays fault code F61 then switches off
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
Feb 28, 2008 | Panasonic SC-HT740 System
I get a code F61 and it wont even turn on.
well i got the same problem .,, every time i want to turn it on, the F61 code comes up. how can i fix it?
Oct 23, 2007 | Panasonic SC-HT640 System
1,005 people viewed this question
 Grubhead
Grubhead
