We purchased a 2007 Jetta just before Christmas. We noticed the tire pressure sensor light was on and have discovered the tires will not hold air. The dealer even replaced the back tires. Still the air pressure will not hold. HELP!
Make sure you refill the tires with the specific amount of air and if it doesnt make the light go away you got a bad tire pressure sensor.
Please dont forget to rate me..
Hello: Check tire pressure, Proper pressure should be on a label on the driver door and door frame. If tires are low, air them up to spec's. If only one tire is low you should check it for a puncture.
That would be for the TPMS (Tire Pressure Monitoring System). This usually comes on due to low tire inflation. Inflate the tire to recommended pressure and the light should go out. You might have to drive the vehicle for a while to get the air to expand.
you will need to go to the place and have the scan the tire monitor computer to see what codes you have. they may have broke one or more of the sensors in the tire that are very expensive. if they don't have the correct machine/scanner then you will need to find a shop that does and you will no more then
Do you have sensors in the wheels? I dont think so, but If you do... I recommend setting the tire pressure at 35, if you set any lower, the light will come on when it gets cold and the pressure drops. Did you also set the spare?
You can reset the light by finding the button underneath the drivers dash, and with the key on, hold the button in until the light goes out. Then let go, and press again, hold until the light flashes 3 times, then it should stay out.
tire reset, light on dash will come on if brakes notice a pressure change in tires/breaking or if any maintence to tires, breaks, change + or neg in air pressure. to reset push and hold button for @3 sec.
