Starting problem Press F4 to resume message always on the screen at the time of starting
  • 818 Answers
Check the cables to your HDD
This can be the problem.
Sergio
Posted on Jul 23, 2008
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Cannon ip4000 error message waste ink almost full
Hi there
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | Office Equipment & Supplies
PIXMA MP 450
try these steps ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
The ink absorber is almost full.
The ink absorber is under the print engine and covers the whole bottom of the machine. It is 5 inches wide and over a foot long. Did you really clean this part? You can't reset the error code without getting into the diagnostic program which only a shop can do...
Jun 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Press f4 to resume
u need to go into bios setup.this can be done by pressing del button on ur keybadr while booting is goin on. some time the key to be pressed will be F10 or F1 instead of del key.
There will be an option as stop booting on error. disabl;e that..n it ll be fine.. btw to find out the error u'l have to specyfy each n every settings in ur bios.So its better u to ask for a person who knows these things to ur home.. Else u can do by exploruing these things urself.It ll be fun..i would prefer this..
Feb 12, 2009 | HP Pavilion dv2000t Notebook
When i start my PC it show first error that is Drive A - error press< f4> for resume after press f4 Pc will be start .
You need to go into the BIOS (by pressing either F1 or F2 or DEL when you first turn on your computer; it should tell you which one to press to go into system settings or BIOS) and disable the floppy drive. Thanks and please take a moment to rate as fixya. :c)
Jan 10, 2009 | HP Pavilion dv2000t Notebook
Prompt to enter setup when started
press del to enter to cmos and set to load setup default and select exit and save changes and if happen again replace your cmos battery.
Nov 24, 2008 | Computers & Internet
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Jul 03, 2008 | Intel Motherboard
It gives pressF4 to resume option
if you only want to get rid of the F4 option then go to setup utility and on select HALT ON NO ERRORS.
it will fix the problem of F4 if the drive works fine.
Jan 06, 2008 | Excelstor Technology J880 Hard Drive
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
