Question about GE Profile Harmony DPGT750EC Electric Dryer
GE side by side refrigerator-1994
Pooling of water/ice in bottom of freezer.
  • 868 Answers
Check your drain pan for water.If you see none than you have a clogged drain line in the freezer.Remove the back wall lower screws and any screws that will prevent you from getting the back freezer panel off,NOTE : this is in the freezer located on the back wall. You will see the drain behind this panel , if its clogged ,un clog it.
Posted on Aug 18, 2008
Water is pooling in freezer and freezing, unit works great i have to break the ice up about once a week though
That ice is from the water of the defrost...its pooling in the freezer and freezer because the drain line is blocked..this tip i wrote will covers how to clear that drain
Sep 07, 2011 | GE Refrigerators
GE side by side Model # TFX25PPBAWW Serial # GT257367 Water leaking out the front freezer side. Ice is accumulating at the bottom where water is poolling. I have removed the Ice maker from the freezer...
You have two things causing this
1) the water valve for the i/m is seeping and not fully closing,with the i/m removed no water should come from the tube and the valve should be replaced(alos it were the from the im their would be ice build up from that tube all the way down to the very bottom)
2) this is the most prabable cause with the abense of ice build except at the bottom around the lowest drawer and that is the defrost drain is blocked,the drain can be found at the very bottom of the rear panel of the freezer and is blocked so instead of the defrost water draining it is pooling at the bottom then running out all over the floor
to clear the drain push a wire hanger through the tube till a small hole opens then flush it with hot water
Jul 19, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pooling under freezer side of cabinet. Ice forming in bottom of freezer.
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
GE Freezer that ice if forming in the bottom of the freezer
drain in bottom rear of freezer is stopped up deice and use turkey baster to force hot water through drain
Jun 24, 2009 | GE GSL25JFR Brushed Steel Side by Side...
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
GE Profile Harmony DPGT750EC Electric Dryer Logo
281 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
