Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
No booting or nothing
My aspire wont boot. press the power button and i get a flash of red light but nothing else . thought it was the power supply so bought new one but still the same. the cpu fan spins for a short time and then stop not sure what is the problem any suggestion?
  • carol2004 Jul 23, 2008
    Thanks i will try that and let you know.
  • ladydarkrose Aug 26, 2008
    Having same problem with my Aspire E380 machine. And my warrenty is out on it now too. :( Any suggestions on how to fix please e-mail me.
    Master:
  • 397 Answers
Narrowing down a fault like this is relatively easy but time consuming.
Please read this thread about building your machine outside of the case.
http://forum.pcmech.com/showthread.php?t=132409
The idea of an "out of case build" is to reduce the amount of hardware in order to eliminate what is causing the problem.
I build computers eveyday and I still use this method from time to time when trouble shooting.
Posted on Jul 23, 2008
  • 28 Answers
Did you have a power surge in your area recently? Sounds like it could have been damaged. Can you press the F8 key (continually) while it's starting to boot & get the setup menu?
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
WE HAVE JUST HAD A LIGHTENING STRIKE AND ALL POWER IN THE HOUSE WENT OFF WHILST MY ASPIRE E 700 WAS POWERED AFTER THE POWER CAME BACK POWER LIGHT WAS LIT BUT COMPUTER WONT START UP WITH START SWICH
Unplug everything from the laptop, remove the battery and let it sit for 5 minutes. Replace the battery only, not the power brick and see if it will boot.
Does the power brick have a solid green light? Flashing? Red?
If it will not boot off the battery or power brick it may be fried.
Jun 28, 2011 | Acer Aspire E700 PC Desktop
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
When i press the power button my acer aspire one.it wont boot
I recommend you try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops.
Also check if there is a known issue with your laptop model since even others are experiencing similar issue.
Jun 25, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Acer aspire 5610
remove power supply then remove battery.
then connect to power supply and try to boot, if no luck then remove power supply and press and hold power button on laptop atleast 10 seconds then in the same postion connect the power supply.
if still no luck then you should take a tour to service centre.
For any more question just ask me.
Thanks
Iqbal
Jun 29, 2008 | Acer Aspire 5610-4648 Notebook
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
207 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
