Question about Hunter 23852 Classic Original Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
Have a Hunter fan. The pull chain broke inside the switch. Replaced
with new Hampton Bay switch, but now, only low speed works.
Suggestions?
Thanks
  • ello_beth Sep 28, 2008
    I have the same problem i tried changing the wires now off and high work I need to know which wire goes with whisch speed.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Posted on Jul 24, 2008
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Hunter fan the pull chain hole is broken 20723 westmimster
It's a low end fan for either Home Depot or Lowes. Call 1-888-830-1326 to order new switch. DO NOT CUT WIRES when replacing switch.
Sep 23, 2013 | Madison Avenue 04889 Hampton Bay Ceiling...
Low and medium fan speed no longer works on our Hampton Bay fan when you pull the chain. The high speed works. Can this be fixed with a repair part?
the speed is controlled by a capacitor bank ... high speed uses no capacitors, low speed uses a small capacitor in series with the motor and medium speed uses a larger capacitor ... the pull chain switch selects which capacitor is used ... so if the capacitors go bad or if the switch fails to select them then you will not have low and medium speed ... so you could have a bad speed capacitor block or a bad switch or wiring that has come loose inside the fan (that connects the capacitors) .. all are replaceable .. i would first remove the covers from the fan and check all wire connections .. check the switch to see if it operates smoothly .. then suspect the capacitor block .. if you were an electrician then you could bypass the switch to test its function but if you are not then make sure power is off while working on the fan .. you should be able to get a new capacitor block from the manufacturer .. most are similar if they will phisically fit in the fan housing and have the same connectors ..
Aug 15, 2010 | Hampton Bay Heating & Cooling
Fan chain broke and i want to put it back together
If the chain broke from inside the fan you will need a new switch $6 at any home improvement store and if its just the chain links you can buy a another replacement one. Make sure you tell them which switch is broken, fan or light so you get the right one and how many speeds if its the fan
May 01, 2010 | Hampton Bay 24002 Ceiling Fan
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
How to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hunter 23852 Classic Original Ceiling Fan Logo
1,839 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
