Home
My Products
Sign In
Back to:
All Products
Copiers
Troubleshooting
Tags
paper jam
what is a fuser
jam
printer paper jam
ht roller
Generic problem for all Copiers
Paper jam
posted by
jaiku
on Jul 23, 2008
Report abuse
hi my hp dj 5943 printer always geting jam. wen i switch on the printer that time paper taking and geting jam in half of the printer. i canceled and give a print comment again same problem. pls anyone give me correct solution.
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on Jul 24, 2008
Guest
Rank:
Apprentice
Rating:
0%, 0 votes
i checked all gears, thats not a problem. when paper reach the sensor then paper comes out 5 inch then geting paper jam. its doesnt start printing.
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on paper jam:
I don't want to Accept this solution
Done
Solution #2
posted on Jul 23, 2008
checkitright
Rank:
Wiz
Rating:
82%, 645 votes
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Done
Suggest a new solution for this problem
This Problem Also Relates To:
Canon imageRUNNER 400S Copier
Canon C330D Copier
Canon CLC 1110 Copier
Canon PC-430 Color Copier
Canon NP 6545 Copier
Canon NP 6650II Copier
Canon imageRUNNER 6020I Copier
Can you Help with these Copiers problems?
Canon USA - COPIERS - IMAGERUNNER 6570...
Canon PC-6re copies are all black
After cleaning the dust proof glass and the corona wire...
Answer This...
Canon imageRUNNER 2200 Black and White...
Streaky Copies
The pages are coming out with inky streaks across them....
Answer This...
Minolta EP1030/1030F CS/PRO Copier
E0 code on Minolta 1030
I have a MInolta 1030 with an E0 code. I know that this is...
Answer This...
Copiers
error F35 ON KONICA COPIER
when i turn on the copier it shows an error f35 - can i...
Answer This...
Canon imageRUNNER 210S Grayscale Copier
Canon Image Runner 210S
I have an error message that reads load A4 in any tray. I...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Bogda
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Copier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
