I have a phillips 60pp9100d that has no picture or sound. I keeps flashing I2c bus error. I have resoldered the flyback connections and anything else that looked suspect. After turning the tv back on I get the same result,I can hear the flyback powering up as before but thats it. Do I need to proceded with replacing the Ic chips or go in another direction?
  • davecc Jul 24, 2008
    The kit that maxnavox help offers won't work on this model.
    Thanks
    David
  • 818 Answers
  • 1,183 Answers
You can get the service reapit kit on the following site with blow images for the board and troublesooting guide.
http://www.magnavoxhelp.com/
Thanks
proton
Posted on Jul 23, 2008
    Guru:
  • 1,894 Answers
I2C Bus Error or I2c bus error??
please tell in detail
  • 1 more comment
  • dewan nafees ahmed Jul 24, 2008
    I (superfix)2 C bus error or normal I2C10
    IC7302 should be checked for in and out voltages to see is its the IC
    istself that is at fault or possibly a leaky diode after or before the
    IC. Checking pin voltages will be the only way to track the problem
    down and isolate exactly whats happening. If you need more assistance
    please let me know
    please let me know
  • 10,594 Answers
You need to rectify the problem first then replace any part. If you have its service manual, try to daignose the reson of error and locate the problem area.
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Help fix error code sc690 on ricoh 2035 copier
SC690 - A GAVD block I2C bus error.
An error is detected in the GAVD communication I2C control register of the GABIC2.
• I2C bus on BICU defective.GAVD IS THE laser controller loacated on the laser unit.
Nov 01, 2011 | Ricoh Aficio 2035 Copier
Sc 690 ricoh aficio 1035
the GABIC2.
But I had this problem with LD Unit and Flat Cable broken. try to locate a loosen Flat cable to the LD unit.
Aug 26, 2011 | Ricoh Aficio 450 Copier
No picture but i have sound on my RCA F32676SB 32"
You do an adjustment on the screen nob on the flyback transformer?Resolders the CRT-(tv tube) YOKE wires R,G,B connections to the main PCB board?Resolders the video board CRT-(tv tube)video board pins sockets that connect the video board and the CRT-(tv tube) together.
Feb 13, 2011 | RCA F32676SB 32" TV
Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
Apr 19, 2009 | Philips 60PP9200D Television
Philips 60 inch projection
The I2C message that you get means the Inter IC communication bus on the system board has gone bad. Replacing the IC would not solve the problem.Philips patented this technology to reduce the number of ICs on the systemboard.There would be a physical I2C chip on the motherboard.
You can read about the technology on the post by philips
http://www.nxp.com/acrobat_download/applicationnotes/AN10216_1.pdf
I would suggest update the firmware on the board, or try replacing the I2c interface controller chip.
Thanks
Proton
Jul 28, 2008 | Televison & Video
Please help.
IC7302 should be checked for in and out voltages to see is its the IC istself that is at fault or possibly a leaky diode after or before the IC. Checking pin voltages will be the only way to track the problem down and isolate exactly whats happening. If you need more assistance please let me know
Jul 24, 2008 | Televison & Video
Have sound, lose picture. D52W23
sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 29" TV
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Feb 13, 2008 | Philips 27PT6441 27" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
