Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
550 Door Seal Doesn't Seem to Be Working
We have a 550 Subzero. Recently we've noticed a lot of condensation on items in our refrigerator section. My husband noticed this morning that the door appeared to be open (slightly) which would account for that. I made sure that nothing was blocking the door from closing and pressed tightly to make sure it was firmly closed. A minute later when I opened it, it didn't appear to be sealed. Is there any way to fix broken door seals or is it time to kiss this frig goodbye?
  • yvesm Aug 19, 2008
    Few year ago the door was sealing very good; it was hard to open it after we just close it but now the door is not closing thigh sometime we find the door slightly open and the inside is getting hot from the lights staying on.
    Is the magnetic seal around the door must be change or is it a solution to my problem?
    Yvesm@aei.ca
  • edwardboyle Dec 15, 2008
    should I use a door seal lube when replacing under lip of seal and metal fisture strips?
  • Sub-Zero Master
  • 5,568 Answers
Since the doors on most refrigerators are adjustable, check the alignment of the door by pushing it close to being closed and seeing if the crack still visible is consistent around the three sides not yet in contact with the frame. These normally don't change much over the life of the unit but you may be able to improve the contact through an adjustment. Considering that the door does not seem to want to stay closed, check too on the hinge side to see if that part of the gasket is striking the frame too early.
Posted on Sep 13, 2008
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Sub-zero 550 refrigerator is too cold--icing at boottom near vegetable bins. Temperature is eratic--a lot of variation between top shelf and bottom and frequently shifting and changing.
It is very common for this refrigerator to have a freon leak in the evaporator.
Since you need a EPA license, This is usually beyond the scope for the home owner to repair.
http://www.on-timeappliance.com/subzero.html
Mar 28, 2012 | Sub-Zero Refrigerators
I have a Model 550 SubZero Refrigerator. I have ice build up on the lowere left rear interior wall just above the criper drawers. Can you advise on cause and fix?
Check your door and door gasket. Make sure it has a tight seal. The ice is from air and moisture getting in on the left side.
I hope this helps. Please leave feedback.
Thank you.
Aug 24, 2010 | Sub-Zero Refrigerators
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
May 12, 2009 | Refrigerators
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Condensation on the top front of the subzero 700 TR Refridgerator
VERY POSSIBLE. door seal is the most painful job. YOU HAVE TO INSTALL PROPERLY. SOME MODELS REQUIRE ADD SILICON. DEPENDS ON THE SERIAL NUM.... . TESST THE FAN JUST PRESSING THE SWITCHES IN THE UPPER PART. ONE FOR LIGHTS ONE FOR FAN.... good luck...... LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU
Mar 25, 2009 | Sub-Zero 700TR
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Jan 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
801 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
halftank123
ACME Sub Zero...
ACME Sub Zero...
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
