2006 Ford Freestyle Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My emmission system light is on. What do I do?
Anonymous
Level 3:
President:
  • Master 496 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
President:
Answers
496
Questions
Helped
372337
Points
1857
Go to a major auto parts store and have them read out the stored trouble code(s). They will do it for free. With the code, you can start to trouble shoot what is wrong.
Left cap off on windshield wiper reservoir cap for few weeks now light indicator cap light on could this have damaged something cant pass emmission test
Depending on what vehicle you have, the service engine soon light for the OBDll system may contain this code. If it does, then that is why you failed. Go to a parts store and see what code is in the OBDll system. Add some reservoir fluid tho the system to turn off the light. It is probably low.
I have a 2001 hyundai sonata, I have a light that is coming on, in the manual it says gas, exhaust light, what is that?
emmission light.
there is a small vapour leak in the fuel sytem of your car.
this doesn`t mean your leaking liquid gas -only a small amount of fuel vapours.
the emmission system of today`s vehicle are very sensitive, and when the car`s computer monitors this, it will display this information thru your dash warning light.
yor car is still safe to drive, but eventually you will have to fix this problem in order to pass a drive -clean -emmission test. See your service repair shop for further diagnostics..
Code large air leak (emmission light stays on)
You need the code
Then you find the problem in the EVAP System
An EVAP Smoke Machine, would have you making the repair in about 3 minutes.
So unless you can find a loose hose,broken fitting Etc,you need professional help.
Then the job is completed with a scanner to test system, I doubt your spending 8 thousand for that piece of test equip.
Now you know why cars cost a lot to fix.
The emmission light in my ford fusion is on what is it
the emmisssion light comes on to alert you to the fact that a fault has occured in the electronic engine and emmission control system, there are over 200 such faults poss and each has it's own distinct fault code that is set in memeory whenever the light comes on, if u have less than 70,000 miles on this car it is likely this will be covered by the US Goverment mandated emmssion system warranty.
6helpful
Emission system service required message came on
Emmission system service Text message on dash board with check engine on light. No code read registered when using code reader. What is the deal here? Do I have a problem?
3answers
My vw golf gti (2000) has failed its mot on emissions. the dianostic machine will not connect to the car. do i have a ecu problem?
HI MOST EMMISSIONS PROBLEMS R SIMPLE IF THE CAR STARTS AND RUNS AND NO ENGINE LIGHT IS ON THERE R 3 TYPES OFF MOT FAILIURE COULD U TELL ME EXCACTELEY WHAT IT SAYS ON UR EMMISSION SHEET REGARDS
Check engine emmission message
the emission system on any car sold n the USA is tested and certificated by the EPA to not pollute for 100,000 miles, these systems include the EGR (exhaust gas recirculation) system, the fuel vapor control system, the catalytic converters, the various sensors on the engine such as lambada sensors and engine temp sensors plus many others
1helpful
Emmission system light
take it to autozone and they will plug in their OBD11 computer and tell you exactly what it means... or take it to any mechanic who has one, my light comes on if i get crappy cheap gas
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
