Question about IBM Wheelwriter 30 Typewriter
How to set memory
I started a job that has a ibm wheelwriter 3500 & I don't know how to set something into memory. I have forms to be typed & would like to "code in" to memory the forms I'll be using regularly.
  • IBM Master
  • 3,594 Answers
On the L. side of the keyboard there are 3 keys store, play and delete.
To store hold code and press store type in 01-99 for an address, rel keys, type info. when complete press store.
To play press play and the address 01-99 to print.
To delete press del. and address.
DickyO
Posted on Jul 23, 2008
When I type, the keys move but they do not stike the ink ribbon.
You probably have a broken solenoid cap. You will need to order the cap but I do not know who has a video or instructions to do it.
Apr 08, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
How do I save a document in the memory of IBM 3500 wheelwriter for later retreival?
On the L. side of the keyboard are 3 keys store, play and delete. Hold the bstore press address 01-99, release the store key, type info, press store when done. To play hold play and type address. Delete works the same.
DickyO
Aug 31, 2010 | IBM Office Equipment & Supplies
How do i restore original settings on the ibm wheelwriter 3500 type writer. It doesnt print text until entire words are input on the lcd
Here is a simple way to record. You have 99 memory slots. Hold the store and press "1" type what you want in memory. Press "store" to close the storage area. When you want to play what you stored, press and hold play and tap "1" it will play just what you stored. You can repeat this 1 through 99 until the memory is full.
Jul 07, 2010 | Office Equipment & Supplies
IBM Wheelwriter 3500.
Does the display show aP/W nomber other than 001?
If it does hold the code key,press and release the "L" key type 001 release the "L" key this sets the keyboard to U.S., if this works the cure is to replace the keyboard.
DickyO
Dec 19, 2008 | IBM Wheelwriter 30 Typewriter
MANUEL
The l. row of keys say save play and delete, hold the save and press 01 to 99 as an address release and type when finished press save again, To play use the same procedure with the play key.
DickyO
Jun 05, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
May 16, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500
Does it beep and type or just beep? If it types try holding code and pressing S. If you changed batteries with the machine off the memory is gone.
DickyO
May 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 15 Series II-Program the memory
The WW15 does not have a recallable memory, it has a reprint memory that will repeat what you have JUST typed, code reprt top left kry on the keyboard will activate if you want a full memory get a WW5 or 6.
Dicky O
May 05, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 6
1press and hold the code key and type the # 1 thru 99 wher you want to store the job(chose any one number)
2 the store light should blink
3 the ARtn light comes on
4 the carrier returnes to the left margin
4 the printwheel spins
5you may begin typing when the store light is on solid
6 let the carrier return automatically at the end of each line of type
7close the store when finished by pressing and releasing the store key
Mar 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
140 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
