Question about Samsung Office Equipment & Supplies
After changing ink cartridges, I am getting pages that have light and dark printing on it like it is running out of ink but it only last until the printer gets hot. It starts back doing it if the printer sits idle for a while. Samsung CLX-3170.
In most cases for Inkjet printers. The cart chg disruption causes a sort of air lock in the ink flow lines. 99.9% of the time you just need to do a head clean.
In some extreme cases (if you are using generic ink carts) you may need to install an original cart again to get the flow right. But you can go back to generic carts after that.
Posted on Dec 07, 2010
  • voltron Jul 18, 2013
    I know this is an older post, but for the record, the CLX-3170 is a laser printer....
HP 1010 12-A CARTRIDGE...
Replace the ink cartridge with another
Jan 14, 2014 | HP 12A Black Laser Toner Cartridge...
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
Error code 0xc19a0023
I went crazy trying to fix my HP D7560, days and days of print ink failure, unable to align cartridges, until to clean print heads. My symptom is that the black ink started to print only in a light gray. I tried everything from running Tools, changing to new cartridges, even buying a new print head (which was not genuine HP, they don't make them anymore, and the new print head would'n't complete in diagnostics without error). I love this printer and didn't want to part with it. So I searched for days and tried many solutions without success. Until I found this one last solution - it my last ditch effort. The solution is to get a bowl of very hot water (not boiling), remove the print head from the printer and place the print head directly in the hot water (sounds risky! but I did it). I watched as the bowl filled with black ink. The instructions said to let it sit for 5-10 minutes, but I couldnt' believe the amount of ink that poured out of the print head. So, I kept replacing the water and shaking the print head carefully in the water to loosen the trapped ink. I repeated this step (replacing water) until it was no longer producing black cloud of ink and water was fairly clear. I carefully dried the print head with a paper towel, let sit for approx 5 minutes to dry some more, shook it vigorously a few times to shake out any water, and then lastly hit it with a blast of compressed air to ensure all water droplets were gone. I put the print head back in, re-inserted the cartridges and the printer ran through diagnostics automatically - aligning cartridges and printing a test page - it was BEAUTIFUL!!!! Until I tried this, nothing worked. I'm hoping this solution will help others. Good luck.
Feb 15, 2011 | HP Photosmart D7560 InkJet Printer
I don't know how to change the ink cartridge of epson tx 110
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Keep ink cartridges out of the reach of children and do not drink the ink.
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Canon IP4300 - the two black ink cartridges
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Can print the color I want. Only prints red.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
I am getting a quarter inch black streak that runs the entire length on the back of each printed page. Sometimes light and sometimes quite dark. I have tried changing ink cartridges but still get the...
You'll have to open up the printer and clean everything off. You probably have a feed roller with ink on it. If you refill, use ONLY inks made for your brand of printer.
Jul 21, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Dirty Cartriage or Printer head
you should clean the printer head or cartriage
Aug 31, 2007 | Lexmark Z715 InkJet Printer
120 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
