Question about GE Refrigerators
We have a GETFX27ILB 26.6cu ft. refregerator an the one side isn't getting below 60 degrees.
  • 3 more comments
  • hchostess Jul 23, 2008
    Why did you send me to a computer expert instead of a refrigerator expert? I have a 13 year old Model TFX27ILB GE refrigerator. The freezer is working fine but the refrigerator won't get below 60 degrees. Please help
    If you don't have a refrigerator expert, please refund my money. I am not satisfied!!
    This unit only has one evaperator fan and it's working.
    this unit only has one evaperator fan and it seem to be working fine.
    The thermostat & evaporator fan is working and I don't know what parts I need because no one cam tell me what is wrong.....just forget the whole thing and refund my money because I am not satisfied with the solutions.
  • 2,071 Answers
Posted on Jul 23, 2008
    Genius:
  • 1,665 Answers
Enter (TFX27ILB GE ) at search tab and click "search" to see parts availability for your model.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
WHAT IS WRONG WITH YOUR REFRIGERATOR
    Brigadier General:
  • 6,966 Answers
Due to the size of most 27 cu ft refrigerators, the design calls for the use of two (2) evaporator fans. The fans draw cold air from the freezer section and blows it to the refrigerator section. It is possible that one of the fans has failed and therefore the area where that fan is located is not getting as much cold air as the other side. Corrective measure requires that the said fan be replaced.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Guru:
  • 1,894 Answers
Have you replaced the thermostat?
how old is the unit?
there may be a problem with the thermostat sir
  • 1,183 Answers
Could you again give us the model and manufacturer for the refridgerator.
Thanks
Proton
The head was done and I need the torque setting for this vehicle.
M10 bolts: 1st step; - 18 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees M12 bolts: 1st step; - 22 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees
2.0 Engine
Feb 02, 2016 | 2005 Hyundai Tucson
Big ends torque settings head torque settings
10 mm bolts
step 1 22 ft lbs.
step 2 60 degrees
step 3 additional 60 degrees
12 mm bolts
step 1 26 ft lbs
step 2 60 degrees
May 26, 2011 | 1998 Hyundai Elantra
What are the torque settings of the j2 1.8GLS 1996 hyundai elantra
cylinder head bolt torque
10 mm bolts
step 1 22 ft lbs
step 2 additional 60 degrees
12 mm bolts
step 1 26 ft lbs.
exhaust manifold nut 32-41 ft lbs.
intake manifold nut 11-15 ft lbs.
rocker cover 71-86 in. lbs.
Dec 14, 2010 | Hyundai Motor 1996 Elantra
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: melissapowers75@gmail.com
Feb 02, 2010 | Chevrolet C2500 Cars & Trucks
My Whirlpool is in the garage. It's cold outside (below 5 degrees C) will it work? Model FRUU36AF20
may not work newer frig's are no longer designed to wirk in ambient temps lower then 60 degrees, gotta love energy efficency
Jan 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
Fridge not cooling 60 degrees
hi thanks for the question did you clean the coils at the back by the compressor if not clean the coils its very important try that thanks the appliance doc
Sep 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
