Question about Brother DCP 7010 Multifunction Laser Copier
Help For the Brother 7020 its says " the back cover is open, close the back cover". Where is the back cover? I've checked and cant find it....
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
One ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Posted on Jul 23, 2008
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
BACK COVER OPEN
The back cover sensor is detecting the back door is opened. Open and close the back door firmly to fix this message.
Aug 22, 2012 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
My Brother DCP 7020 won't stop flashing close back door
There's a micro-switch that "trips" when the door is opened/closed. It's not sending a "closed" signal to the printer. Clean the switch, with a blast of compressed air. Check that a small "finger" is going-in to the slot, to "trip" the sensor, as the door is closing.
May 07, 2010 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother printer
One of 2 things has happened.
There are 2 types of switches used as interlock witches on those covers.
Mechanical switches, where there would be a small opening in the frame where the cover is. It may have fallen out of the snaps of more then likely the tab that actuates the switch has broken off. look carefully with that cover open and see if a tab is broken.
You can cheat it with some not conductive item put into that opening to actuate the switch and tape over it. Then order a new cover, That's the most likely.
There are also magnetic switches used in some covers and possibly the magnet has fallen off not actuatinng the switch.
Once you locate the switch you will locate your problem.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
The printer jammed and now will not restart
unit was turned off while it had this error, follow these instructions:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=4
Dec 03, 2007 | Brother DCP-7020 All-In-One Laser Printer
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7010 Multifunction Laser Copier Logo
102 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
