Question about HP Compaq nx6310 Notebook
How to remove keyboard HPcompaq nx6310?? cause, I want to clean the headsink
    Genius:
  • 2,028 Answers
Here's a link to the maintenance and service guide for the nx6300 series. It has keyboard removal instructions and diagrams.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00805752/c00805752.pdf
Posted on Jul 23, 2008
Hello,my laptop HPCOMPAQ 6735S boots with a series of continuous beeps.Plz help me to solve this problem.In touch.
hi
1. make sure that any key is stick on the keyboard,
2. you will have to remove all key, one by one until the beep sound stop.
if the problem continue then, you have to open the case and disconnect the keyboard cable from
the laptop mainboard, close the case. Then use a mini or normal size USB keyboard
hope this helped you to solve the problem
May 28, 2011 | Computers & Internet
Cleaning the nx6310 keyboard.
use a paintbrush NOT A VACCUUM CLEANER as it may **** the keys off
Please rate mmy help++++Thanks for using FIXYA
Jun 19, 2010 | HP Nx6310 Notebook
Need to remove the space bar to recover a lost bead
You shouldn't have to remove any keys, try this >>>>>
Get yourself a clean dry paintbrush, turn the laptop off but leave the lid open, turn it on its side and gently brush the keys, gently tap around the keyboard with the back of the brush to knock out any foreign objects or beads that maybe trapped under the keys.
Good luck.
Aug 20, 2009 | HP 413669-001 - HP Compaq nc6320, nx6310,...
Hello expert
try cleaning it before you mess with any settings.
Cause:
Your keyboard or number pad may collect dust and other deposits from regular use. Occasional maintenance helps keep the device looking clean and functioning properly.
WARNING: Before cleaning any electrical device or equipment, ALWAYS remove the device from its power source.
Solution:
  • For cordless keyboards or number pads, remove all batteries before cleaning.
  • For the diNovo Edge (a rechargeable keyboard with a built-in, non-removable battery), or any other similar device, switch the keyboard OFF before cleaning.
  • For corded keyboards or number pads, shut down your computer and disconnect the keyboard from the computer before cleaning.
Keyboard and number pad cleaning suggestions:
  • Use compressed air to blow dust and other debris from between the keys. Logitech suggests using an air duster squeeze bulb specially made for keyboard cleaning to limit the force of the air pressure.
    NOTE: Avoid using high pressure air hoses and nozzles. Excess air pressure can remove keys or cause other damage to your device.
  • Use a small tipped vacuum cleaner to remove dust and other debris from between the keys. Logitech suggests the use of a small tipped vacuum cleaner specially made for keyboard cleaning. Many come with USB power cords and can run off your PC or laptop.
    NOTE: Avoid using vacuum cleaners other than the type previously described. An excess vacuum level and/or large vacuum tip can remove keys or cause other damage to your device.
  • Use a dry, lint-free, non-abrasive micro-fiber cloth to gently wipe clean the surface of your device. Logitech suggests using cloths which are specially made for keyboard cleaning.
    Note: Avoid using dusted disinfectant cloths or cloths dampened with liquids unless specifically designed for keyboard cleaning. Many cleaning solvents, chemicals, and other liquids can cause electrical and/or material damage your device. This includes leftover residues which can eventually damage your device over time.
Additional information:
Many consumer electronics stores and online re sellers offer third-party computer cleaning kits which include dry wipes, swabs, air duster bulbs, and micro-fiber cleaning cloths. Some higher-end cleaning kits come with keyboard vacuum cleaners, and/or product-safe disinfecting liquid for dampening wipes, for use in disinfecting the surface of the device. These liquid disinfectants are supposed to be non-conductive electically; quickly evaporate from the sevice and leave no residue. Logitech suggests you make sure these characteristics are plainly stated and guaranteed on the product package. These specially made keyboard cleaning kits are highly recommended.
IMPORTANT NOTES:
  • DO NOT pour any liquids onto the device.
  • DO NOT submerge the device in any liquids.
  • DO NOT use a dishwasher, ultra-sound cleaner, or any other washing machine to clean your device.
  • DO NOT remove keys from the device.
  • DO NOT use cleaning solvents. Many cleaning solvents contain caustic chemicals which may cause damage your device.
  • DO NOT use drying machines, fireplaces or ovens (even set at lowest temperature) to dry moisture from your device.
Removing keys; submerging or pouring liquids on your device; using washing machines; exposing your device to excessive heat; or using caustic cleaning solvents may cause permanent damage to your device and will void the warranty.
Feb 27, 2009 | Logitech Cordless Desktop MX 5500...
Laptop screen dont like keyboard slot ram
The NX6310 laptop supports up to 4 Gb of RAM either 533 or 667 MHz DDR SDRAM.
When memory upgrades don't work, the problem could be incapable memory between RAM modules.
Try to use RAM from the same manufacturer, especially the manufacturer of the working RAM.
Use RAM that have the same speed specification.
Jan 21, 2009 | HP Compaq nx6310 Notebook
How to remove bios password HP nx6310
Remove the BIOS battery, wait about 1/2 hour , re-insert the battery then boot up the computer
Nov 18, 2008 | HP Compaq nx6310 Notebook
Hpcompaq nx8230 doesn't start.
Keyboard circuit is already shorted. You must clean the the keyboard portion inside the laptop because there are still liquid there. You have two options. Call the laptop provider to fix that issue or claim your warranty.
Nov 13, 2008 | HP Compaq nc8230 Notebook
Reds light's
you can't just remove the 2 x clamps, you need something to hold the heatsink down. Get yourself some m5 screws and washers and screw it down to hold the headsink, cpu and the board together.
Jul 27, 2008 | Microsoft Xbox 360 Console
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
HP Compaq nx6310 Notebook Logo
1,066 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
