Question about HP Office Equipment & Supplies
Yesterday our power flickered off and then about 5 minutes later it came back on. And now-my brand new printer will not come back on. It's plugged in (to a working outlet). My printer is the Officejet J6480 All-In-One. I love my printer and all of it's features. Please help!!
    Genius:
  • 1,447 Answers
Hi-
Try another outlet or try another power cable if you have a spare or if its replaceable. If all fails and product is under warranty, call manufacturer for replacement.
Thanks for using Fixya!
Posted on Jul 23, 2008
I have a Coby tftv2617 and have it hooked up to cable. Sound goes out after 10 mins. I can turn it off then on again and it will work again for another 10 mins. What is wrong with it?
Unplug the 110-AC power source, wait maybe a minute, then plug the power back. I have the same malfunction issues with my cable box, cellphone, cordless phone, flat-screen TV, and laptop PC. Disconnect the AC power and remove the battery, wait one minute, then replace the battery and 110-AC power, and it works OK again.
Its a software glitch; when you remove all power source, it reboots and the glitch is deleted, but it returns a week to a month later. Manufacturers purposely included this to psyche you into junking your old electronics and buying new. Observe this never happened until AFTER 5 years had lapsed since you got it brand new.
Nov 29, 2013 | Cars & Trucks
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Platinum keurig no power
under the warranty they mist give you a new one
Apr 10, 2012 | Keurig Platinum B70 Coffee Maker
My Maxent mx-50x3 has a intermitten problem, when I turn it on, it does not have a picture, 5 minutes later it will flicker than a couple minutes more it has a picture while flickering, another ten minutes...
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
Aug 20, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
My samsung refrigerator goes off everytime the electricity flickers, even for a flash or less than a second. It goes off and it does not comebacks on for as much as 24 hrs. Sansumg's technitions says...
The fridge can cut off if there is a power flickering or variation as the relay will be energised to trip off. Once the fridge is off the self timer - 5 minutes- will be active to allow the gas/oil to come back to the compressor as the flickering would have produced an irregular pumping.
After about 5 minutes the processor will energise the relay to contact and start.
Now the main issue is the voltage in your household. if the voltage is low then the fridge will not start again as it will click and shut off. So make sure that there is sufficient voltage in the mains supply. Also the plug point where the fridge is connected must deliver good voltage/current as the wiring must be good to carry the load . If not the fridge will trip off whenever there is a power flicker.
Finall if the power is good then the fridge mut be checked as it cannot be off for 24 hours. register you complaint for warranty service.
If power is irregular use an auto- voltage stabiliser .
Aug 09, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
Error message
Canon has a decent trouble shooting guide for this model: http://tinyurl.com/rgu6o Click on the Step-by-Step Troubleshooting link under Tech Support Unfortunately for this error code, all it says is this: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
Sep 14, 2006 | Canon Pixma MP500 All-In-One InkJet...
Ben Johnson
