Question about Hampton Bay 24002 Ceiling Fan
RFEMOTE ON FAN WILL NOT SHUT OFF FAN OR LIGHTS AND FAN IS ON HIGH
  • knightd Jul 31, 2008
    ours is on medium and we have taken the fan apart.  We have reset the two blue boxes to the same code.  The one in the remote, above the battery.  And we also set the one in the fan after taking the entire fan apart to get to the box on the fan that was to close to the ceiling for us to get access to as well. We are still stuck in Medium speed with no control from the remote. HELP!!!
Did you ever resolve the problem? We are in the same predicament but the fan is stuck in reverse.
Posted on Aug 15, 2008
What is broken that keeps my ac fan running. It will not shut off.
Most likely the thermostat is set to fan-on or bad fan center in furnace if its a newer furnace the circuit board is bad.
Nov 11, 2015 | Heating & Cooling
2011 Nissan Titan heater/ac fan blows on high we replaced the VBC it did not fix it, now what?
What is VBC? Ah, probably Variable Blower Control? my guess you got wires crossed, or a short around the control or even direct short to hot (12vdc) wire. Double check your work, wire connections. Instructions? with the new? double check.
Feb 27, 2015 | 2011 Nissan Titan Crew
On a 2007 lincoln navigator the a/c fan motor will not shut off. the fan adjustment bars are showing slower but still the fan is on high
The fan speed reostat is broken or the switch itself is bad. Try replacing the switch first because the motor speed reostat is part of the motor itself. $$$
Aug 30, 2014 | 2007 Lincoln Navigator Luxury
Unit will not stay on
Is the fan that cools the projection high intensity bulb running? This sounds like an overheating condition, there is a temp sensor that will shut the machine down if it senses the temp is to high and poses a fire hazard or further damage to the projector.
Jan 15, 2012 | Optoma HD80 Projector
Just installed Mr Heater Big Max 45 btu. Ran for two hours then exhaust fan made a high pitched noise and shut off. I turned unit off via thermostat and now all I get is three blinking lights and no...
with the unit unplugged try to turn the fan blade. If its hard to turn than this is a problem. You can try to oil the fan if it is hard to turn.
Dec 30, 2011 | Heating & Cooling
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
Dual Dimmer / lights go off when fan not on high.
I'm not sure of the exact wire arrangement, but it appears as though a fan and light wire are mixed up, as thought the lights are feeding off the fan wire. Its possible that in the switch box or even in the fan box the output of your fan is tied to the lights so that when the fan is at it's highest output (maximum current), yours lights work properly and not at any other setting. Check wiring for errors.
Dec 25, 2009 | Hunter 52" Ceiling Fan With Light And...
Heater Fan does not work
Sounds like the fan control knob has shorted out. You can check the fan "blower" relay and fuse in the engine compartment but you need to make sure the control knob is good or you will keep blowing fuses and relays. If your blower fuse and relay are good, then just have the control knob checked and replaced if needed.
May 08, 2009 | 1999 Volkswagen Passat
1995 Buick LeSabre heater fan
your blower control has gone bad it is under the cowl panel on firewall only way to repair is replace this it will be about in the middle of the air box. should be a plastic panel with i think three finger screws you remove it and will see it
Sep 01, 2008 | 1995 Buick LeSabre
Hampton Bay 24002 Ceiling Fan Logo
52 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
