Question about Goodmans W280NS Television
Goodmans LD3755HD Picture Problems
We've had the above TV for a year and no problems but last night the picture started getting 'grainy' and then broken coloured lines appeared over the programme and then eventual the picture disappeared completely and various coloured lines and blocks appeared.
I have disconnected the power, etc and when re-turning the TV on it is ok for a few minutes then the problems start again.
Please can you help? This
  • 1 more comment
  • tomchik Jul 25, 2008
    There is no problem with the signal source. I need advice to locate the component area e.g. video processing chip, condensors etc.
  • tomchik Jul 29, 2008
    I have changed the main board and the power supply and the same fault exists. The picture is poor from all sources and after 30 mins it breaks up into two distorted pictures with cloured lines and bars.
  • tomchik Jul 30, 2008
    Filter circuits are OK. Output from main board is fine.
  • 10,594 Answers
Let me give you Technical tip. Find "IF Block" in TV, it would be near Tuner, Open the IF Block and resold it with solder iron. make sure not to make bridges between solder points. Reason of problem in your TV is .."acostic tuning frequency drift". I dont know, how to clear my point. But I am sure, this will solve your TV's problem. Good luck.
Posted on Jul 30, 2008
  • 813 Answers
U have problem in filter ckt u have chnage the capcitor
Posted on Jul 29, 2008
    Brigadier General:
  • 6,966 Answers
Pls try using the TV with pure video signal only such as a DVD or even an old VCR. If the problem persist with the DVD, then yes it could be the video processor, if not than chances are it is the built-in tuner of the TV (most likely). Since the tuner block is a single assy, then it would be relatively easy to identify and replace. Often, it would look something like below.
If on the other hand, it is the video processor, then your best would be to get hold of a service manual or at the very least a schematic diagram with voltage readings if you are considering a do-it-yourself repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 25, 2008
  • 796 Answers
The problem is with you tv signal...
when the signal is ok the picture will be clear
Posted on Jul 23, 2008
2 Suggested Answers
  • 191 Answers
SOURCE: Goodmans LD3755HD Picture Problems
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Posted on Oct 11, 2008
Can anyone tell me why all of my BBC digital channels have no signal at night or the early morning, but work again during the day!? thanks
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture.
Jul 26, 2014 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
I have a 32 in,goodmans lcd tv.after about 30 mins the picture and the sound start to crackle,then it turns off.it has to be left for a while,then it can be turned back on,but only for a few minutes,and...
I'm afraid I don't have the solution but a very similar problem, although I just get the speaker crackle, rather than any problems with the picture/the TV turning off.
Did you manage to resolve it?
Aug 05, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
LG 42" Plasma - Sound but no picture
HI,
I'll think that either your backlight or de backlight -driver, -supply is not OK.
Kind regards,
Gerard
Oct 21, 2008 | LG 42LC2D 42 in. LCD HDTV
Distorted picture
still having to do with your power anyway make sure your mains is not too high or fluctuating .if buy a voltage stablizer then change your power module
Jul 23, 2008 | Goodmans W280NS Television
Jan 05, 2008 | Goodmans W280NS Television
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
235 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
