Lost Access to router
Cincibaron here. Thanks for the tip. So far, still no luck. I followed your tips andtried a few more of my own. Still cannot access my router
    Genius:
  • 1,689 Answers
Sorry to hear about that, the steps i gave were actually some of the last diagnosis to tag the device as defective, check your warranty, most Linsys routers have 3 years on them, you may still be able to get it replaced.
goodluck
Posted on Jul 23, 2008
How to change my password and username on my huawei router
Hi
Default router address access codes are mostly 192.168.0.1
They can be 192.168.1.0 or 192.168.0.0 or even [ending in] .254
Make sure your router is switched on, turn on your device and make sure WiFi is switched on.
In the browser address box (top of your browser and make sure it's blank) type in http//192.168.0.1 press enter.
It should get you into your own router settings. Enter in your factory default password and any other code you might have.......
then go through the settings to find the things you want to change.
Tip: write down any changes you make first !
Tip: when you are happy with your choices, save them before you exit.
Tip: clear your cache and close down any settings pages.
Job done !
(check your router device for the default passwords, usually on a sticker somewhere on the thing itself).
Good luck Red.
Jul 29, 2016 | ZTE Mf60 Portable 3g Gsm 21mbps Wifi Usb...
Tip
Forgotten Router Password? Or the Network Key?
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Jan 03, 2009 | NetGear DG834G Router
Will not hook to my internet. we had a storm and lost power. now it will not connect back to netflix
Hi
This often happens with Routers and modems after a power cut.
Turn the router of and on again or press the reset button at he rear (some reset buttons are pressplates that you need a pen tip to press and hold for a few seconds).
After this, the router should reset itself and your internet access should be restored.
I hope this helps.
Aug 27, 2011 | Computers & Internet
I can'n access the 192.168.254.1 i really dont know the username and the passwordfor my huawei bm662i wimax cpe.
The router setup page should be 192.168.1.1
You should be able to access it if you use that address. If you are unsure about your router's ip address, please check my tips and tricks about how to find it out. Click here.
Hope this helps.
Jun 27, 2011 | Computers & Internet
How do i reset the login and password?
You can reset it with pressing RESET button for 10 seconds it is in the back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Let me know if you need further assistance. Thanks for using FixYa.
Jan 15, 2011 | NetGear WGR614 Router
Intermittentconnection to the web,when i
Try a reboot of the router.Power off pc.
1 Disconnect all cables to router except power cable.
2 Find reset button on router probably in back,small button.
3 Using a paper clip or pen tip while power is on hold button in for a minute.
4 power off router and reconncet all cables,power back up.
5 start pc.
If still a problem call your provider,MAy need a new ip address or router.
Thanks and good luck.
Jan 13, 2010 | Sitecom Computers & Internet
Excel Password
Follow the below mentioned link :-
http://www.online-tech-tips.com/ms-office-tips/how-to-remove-crack-or-break-a-forgotten-excel-xls-password/
Any further help, let me know.
Thanks for using 'Fixya".
Jun 04, 2009 | Computers & Internet
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
WEP Setup
You can download the manual & get setup tips / FAQ from the link below: http://us.zyxel.com/web/support_download_result.php You will need to search for your exact model number as there are a few variants. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 23, 2007 | Zyxel Prestige 662HW Router (91004371001)
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
