Question about Kenwood Audio Players & Recorders
Strip between front radio/CD holer and base unit bsnapped.
  • 2,071 Answers
Just repair the strip,put an epoxy, so it holds together the holder...
Posted on Jul 25, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
    This is the wiring codes
    2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Pink
    Car Radio Accessory Switched 12v+ Wire: Brown/Red
    Car Radio Ground Wire: Black/Dark Green
    Car Radio Illumination Wire: Orange/Dark Blue
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger: N/A
    Car Stereo Amp Trigger Wire: Dark Green/Red
    Car Stereo Amplifier Location: Located behind the glove box.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Dark Green
    Left Front Speaker Negative Wire (-): Brown/Red
    Right Front Speaker Positive Wire (+): Violet
    Right Front Speaker Negative Wire (-): Dark Blue/Red
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown/Yellow
    Left Rear Speaker Negative Wire (-): Brown/Light Blue
    Right Rear Speaker Positive Wire (+): Dark Blue/White
    Right Rear Speaker Negative Wire (-): Dark Blue/Orange
    Dec 25, 2010 | JVC Car Audio & Video
    Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
    There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
    The car should have the following corresponding wires:
    Radio 12v--- orange
    Radio Ground--- black
    Radio Ignition--- yellow
    Radio Illumination--- brown
    Dimmer--- gray
    Power Antenna--- pink (if you have one)
    LF Speaker +/- tan - grey
    RF Speaker +/- lt green - dk green
    LR Speaker +/- brown - yellow
    RR Speaker +/- dk. blue- lt. blue
    The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
    Aug 28, 2010 | 2003 Oldsmobile Alero
    How do you remove radio from dash this is the second time we have had a cd get stuck in radio
    if its the original fitment .go to halfords or similar and purchase a pair of bent radio hooks they slot into the 4 holes {2 on either side of the unit } push them in until you hear a click than simultaneous key pull and the unit will come out from the dash .you will have to then strip down the unit to remove the CD its unusual for this to happen as the factory fitment is a very high quality unit .and you will find removing a CD from it hard work as you will require power to eject it {however if the car still have any warranty ..take it back and thy will replace you CD tuner
    Jun 15, 2010 | 2005 Hyundai Tucson
    Car front two speakers arent working. rear two are.
    have the front speakers ever worked?
    if not have they been connected properly?
    if yes then
    look under ballance and check theat rear and front ballance is in the middle
    if it is then for temporarily replace the front speaker with any old speaker
    if that works then you need new front speakers
    if no then the radio is broken
    but what you could do is rewire the back speakers so they also play though the front ones too
    this can be done from behind the radio
    find the rear right positive and negative wires
    strip the insulation but dont cut the copper wire
    cut the front right speaker and attach that to the rear speaker wire
    do this for both positive and negative
    rear right
    positive
    ..v
    ..v
    I...I
    I...I
    I...I
    .I.I..........< strip cable but do not cut metal
    .I.I..______________
    .I.I=_______________ <<<front right positive
    .I.I
    I...I
    I...I
    I...I
    I...I
    Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
    Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
    Constant 12V+ Green/Yellow
    Switched 12V+ Yellow/Black
    Ground Black
    Illumination Blue/Red
    Dimmer n/a
    Amplifier Remote Blue
    Antenna Right Front
    Front Speakers 5" x 7" Doors
    Left Front (+) Orange/Green
    Left Front (-) Blue/White
    Right Front (+) White/Green
    Right Front (-) Green/Orange
    Rear Speakers 5" x 7" Rear Doors
    Left Rear (+) Pink/Green
    Left Rear (-) Brown/Yellow
    Right Rear (+) Orange/Red
    Right Rear (-) Black/White
    THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 08, 2009 | JVC KD-G210 CD Player
    Wiring color code for xr-c5100
    I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
    Top row, left to right:
    White - Front Left (+)
    Green - Rear Left (+)
    Purple - Rear Right (+)
    Gray - Front Right (+)
    Blue/White strip - AMP REMOTE (Max 0.3A)
    Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
    Red - Power (Accessory)
    Black - Ground
    Bottom Row, left ot right
    White/Black - Front Left (-)
    Green - Rear Left (-)
    Purple - Rear Right (-)
    Gray - Front Right (-)
    BLANK
    BLANK
    BLANK
    Yellow - Power (Battery)
    One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
    The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
    The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
    Important notes:
    If there is no ACC power line in the car, do not connect the red lead.
    Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
    This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
    (Posn A is for normal use, with red line on ACC)
    The RESET buttom should be pressed after installation, before initial use.
    Hope this helps.
    Jan 08, 2008 | Sony XR-C5100 CD Changer
    GES050 undercounter radio/cd player
    ..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
    Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
    Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
    It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
    Sep 18, 2007 | Audio Players & Recorders
    16 people viewed this question
    Top Kenwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Don Hart
    Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
