A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
  • 1,420 Answers
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Posted on Jul 23, 2008
No heat
Check if you soldered it correctly, if not, the relay might have been damaged, you might need a new one
Jun 25, 2013 | Frigidaire GLEQ2152ES Electric Dryer
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Inline circuit breaker trips around 8 pm each evening - no other electric appliance is on that circuit.
mcdevito75 here, You could be in an area where the electric load is heavy and itdoesn"t have to be heavy in your home, your utility could be a bit overloaded, you can try to claen your filter, and or raise the temp setting on your unit to no cooler than 65 degrees. Contact your electric about their output of electricity.
Jun 25, 2010 | Samsung AW0503B Air Conditioner
I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Dec 22, 2009 | Kitchen Appliances - Others
Breaker trips on condenser unit on heat pump after several hours of operation
Hi, check amps on unit, and make sure breaker matches, check unit voltage tag, it will tell you what size breaker you need, or may be breaker is loosing resistance, replace breaker, if problem continues, a/c maybe over working because of high temp, temp. affect amperages, and that would be normal, if it trips after few hrs. also check a/c for lack of freon, sometimes, they need a tap up of refrigerant, not enough freon and they would run longer, get hotter and eventual trips. breaker doing his job. good luck
Aug 03, 2009 | Amana PTH123B25AJ Heat Pump Air...
A/c doesn't remove moisture in the room? even when exchanger is set on open or closed--no moisture in collection tray either model #agj3211daxt2    G.E.
An A/C unit is a dehumidifyer BUT Unit are rated in Pints of water, a Unit in Florida might need a de humiditiyer connected to it, the air is heavy with humidity. Another reason is that the Unit is under sized or not allowed to run long enough (?) Infor. on what State you live in would help and the size of the apt. or house the unit is covering. The best T / H would be 70* and 55 H and that would be on the cool side for most people , avg temps in a house would be 74* 65%, body temps are 98.6 most A/C unit are rated at 90* amp temp ( outside ) if the condenser is dirty this will cut the performance on a hot day over 85* Keep unit clean -replace filter (s) . If your getting a 15 degree reading between outside and inside your doing good the best would be 20 degrees ( depending on heat load) windows, and sun. Actic fans remove 30% of the heat -it will drop the temp from 120 to about 85, this can save you a lot of money in A/C bills and help cool the house in warm day when you don't need the A/C.
Apr 27, 2009 | GE AGQ10AJ Wall/Window Air Conditioner
Help me fix my dehumidifier
What else is on the same circuit? Have you added any other appliances on that same circuit that were not on it before?
If no>>>you probably have a short in the unit, and it is grounding out>>>tripping the breaker before it starts a fire.
Also, check the breaker, they can go bad.
Jul 23, 2008 | Kenmore 53509 Dehumidifier
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
