Question about HP DeskJet F380 All-In-One Printer
Printer I CAN PRINT FROM THE COMPUTER JUST FINE. HOWEVER THE PRINTER WON'T COPY IT HAS WHAT LOOKS LIKE AN "E" AND THE NO PAPER IS FLASHING THE ONLY BUTTON RESPONDING IS THE POWER BUTTON
  • Anonymous Jul 24, 2008
    I have the same problem with the E. Mine won't scan or copy.
  • 22 Answers
Try to change the paper you are using..
Posted on Aug 26, 2008
Photo paper jams when I try to copy print, or copy from computer. Copy paper works fine
Hi Lawrence Lewis,
I would be happy to help you with your Officejet printer. If I understand correctly, you can print and/or copy on plain paper, but not on photo paper, is this correct?
What printer model do you have? How Do I Find My Model Number or Product Number?
Knowing your printer model will help me to better assist you.
I look forward to hearing back from you.
I work on behalf of HP.
Jul 13, 2015 | HP OfficeJet Office Equipment & Supplies
I was printing and everything was fine. Now, I hit start to copy an item, printer waits about 30 seconds, and shoots out a blank paper. I know I was low on ink, so I replaced the cartridge. It prints the...
You printer probably needs to be reset. First, remove both cartridges from the printer. Unplug the power adapter from the back of your printer(small black box behind your printer where the power cord is attached)
(model shown may not be your printer, however, the steps are the same)
Wait for at 10 seconds before reinserting the power adapter back into the printer. When the printer turns on and looks for the cartridges, reinsert both cartridges. Let it print the test paper again. Then try to print your document again to check if it's working now.
Apr 04, 2011 | Lexmark X6150 All-In-One InkJet Printer
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Get paper mismatch error.doesn't happen if I just copy,but has started giving paper mismatch everytime I try to copy from computer. I have tried everything suggested in tutorials. It doesn't copy if I just...
Clean the sensor on the right side bottom of the carriage assembly with a damp Q-tip. That sensor gets covered with ink and can't see the paper properly. You clean the underside that looks down at the paper as it passes thru...
Jul 21, 2009 | HP Photosmart C5580 All-In-One InkJet...
Epson C84 paper light is on and power light is flashing what can I do?. E Green.
Please check if there are any foreign objects inside the printer. And unplug it from the computer and test if you can print just using the printer itself without using the computer.
Make sure there is paper loaded on the printer and the printer is OFF.
Hold down the paper button and press and release the power on switch, if you can see flashing green light release the paper button. Just wait till it feeds on paper. If it feeds on paper and prited on a pattern it means the printer is working fine, but if not you have to call your manufacturer of your printer.
Feb 28, 2009 | Epson Stylus C84 InkJet Printer
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
My all in one wont copy/scan, but will print
If you arnt putting the original upside down then it will need scanner replaced, no easy fix... approx $Aus250.
Dec 13, 2007 | Brother MFC 9700 All-In-One Laser Printer
HP DeskJet F380 All-In-One Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
