Question about Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A won't turn on
Hi, I did order power supply from Vance baldwin and changed it. But my LCD stilll doesn't work. Maybe the main board or something else. Please help. Thanks
  • 34 Answers
It could be a inverter board I would try to replace that first
Posted on Jul 24, 2008
Visio HDTV 10A
Check and replace its main power regulator [SMPS] board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Generic 32" vizio l32 hdtv 10a high...
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Jun 06, 2011 | Vizio L32 32 in. LCD HDTV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. sign in as a guest. I will warn you the cost of the board is high.
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L23 HDTV 10A
Sounds like the power supply board blew. You can purchase a new one directly from Vance Baldwin. They are the only parts supplier for Vizio.
It's just plug and play. remove the old circuit board and replace with the new one. Not difficult and it should solve your problem for less than $100.
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Vizio l32
Maybe you need change the power PCB.
Jun 27, 2008 | Vizio L32 32 in. LCD HDTV
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
May 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32
I've got the same problem. I think we got what we paid for. It's either a power supply (internal) problem or an internal electronic board problem. Either way, Visio charges around $300 for the repair. I'd just save the $300 and put it toward a TV not sold at walmart.
May 02, 2008 | Vizio L32 32 in. LCD HDTV
Television Powers Off While Watching
Possibly set was droped at sometime are just hit hard. Maybe loose connection in powersupply
Aug 08, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32
i took it to the tv repair sop and my power supply printed circuit board was blown and it would have cost $609.00 for labor and parts
Mar 05, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
155 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
