Question about Xerox Office Equipment & Supplies
Xerox xc 830
Copies are fully black streaked on 1/3 of page followed by 3/4 inch white then 1/2 inch black 3/4 inch white, 3/4 inch black then white the rest of the page. No difference on any type of original or if I just copy with no original and the cover down.
  • clicker1944 Jul 25, 2008
    What is an ROS unit?
  • 79 Answers
Pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Posted on Jul 23, 2008
  • jai kumar
    jai kumar Jul 26, 2008
    my friend pls check lamp carrage unit if u can pls lubricate in carreage assembly. and chek and lubricate main motor drive assembly. this two thinks is a main reason for that problem..
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
I HAVE A XEROX XC-830 COPIER AND THE FIRST INDICATOR LIGHT ON MY LEFT IS ON. THE COPIES ARE COMING OUT WITH BLACK LINE IN THE MIDDLE.
Sounds like copy cartridge is bad or old. Probably drum. If there's round symbol that's on, that's it....Drum.
Apr 03, 2010 | Xerox 8830 Copier
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Xc 830 problems
why not take the developer and drum units out of the skew copy one and put them in the other? At least that will tell you if dev/drum/toner is the problem.......
Skew copies on the other...look for torn corners of paper tight in the end of feed chutes etc, sometimes clearing a jam will leave a bit in there enough to slow down that side of the feed.If you can see any rollers make sure they are closed and parallel to each other and clean...
Jun 12, 2008 | Xerox 8830 Copier
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
