Question about Yamaha HTR-6030 Receiver
Remote I have a motorola dvr set top box and when I press guide, exit, replay, record, info, or live from the dvr remote it will change the volume on my yamaha 6030 receiver. The dvr remote is not programmed for the receiver. The volume changes by 20db up or down. It is very annoying, I know there is no fix for this other than getting a new receiver brand. My sony did not do this. Has anyone had this problem?
I returned the Yamaha and I bought a Sony receiver.
Posted on Jul 29, 2008
Remote will allow you to "choose an activity" to
Hi. It sounds like some of the IR commands on your remote (menu, exit, guide, info, play, skip, etc.) for your TV and DVD player are not correct. Luckily, the Harmony remote is a Learning remote, meaning you can use your original TV or DVD player remote to teach the Harmony remote the correct commands. The following tutorial by Logitech will assist you with this:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
Dvr restart
WARNING: this will wipe out all of your recordings, all scheduled recordings, all series recordings (your series priority list), and all manual recordings!! Write down everything you can before you do this!
  1. The DVR should be turned on. Press CABLE, POWER to turn off the box.
  2. Immediately press OK/SELECT to bring up the diagnostics page.
  3. While on this screen, press the following key sequences press the counter-clockwise arrow (REPLAY on some remotes) 2 times, then press the MyDVR (LIST on some remotes), button 3 times then the live button 2 times."Clr" will appear on the LED display.
  4. Press OK/SELECT to proceed with the reset. The STB should now reformat the HD & then perform a STB reset and begin to reload your Cable settings and Time Settings from the Head End. It will then begin to populate the Guide data over the next 2 - 24 hours.
On some systems, the button press pattern may be 1-3-1, not 2-3-2 as above. This is true for at least the DCT 3416 I on Shaw.
Feb 17, 2011 | Computers & Internet
My receiver wont stop recording after the program ends it will just keep recording how do i stop this
My name is Anthony Thomas with DISH Network Customer Service. This issue is usually due to a faulty program guide with "No Information Available" or incorrect information as to when the programming ends. This can be caused by a faulty Electronic Program Guide (EPG) download, a faulty box, or by signal loss. By pressing the guide button to bring up the guide, and then pressing the numbers 999 and then browse (the right arrow by select) it should give a message that says "The guide information is outdated, download from satellite now?" or something similar. Try it and see if that helps.
If not, that means there is likely a signal issue or an issue with the DVR. To check signal, Press Menu (top left corner of remote under SAT, has three horizontal lines on it), and then press 6-1-1 like you are changing the channels. That should get you to Point Dish. Check Switch will be an option on the right side. Select it and then select TEST at the bottom of the Install Summary screen that will show up. Select YES if there is a warning about TV2, otherwise it will bring up a 058 message saying to wait while test is done. The message 058 will disappear by itself. If a warning 836 message appears, your issue may require a technician due to signal loss. If not, select done to exit Install Summary, Done again to exit Point Dish, and then press the 0 button three times to select the cancel option. This should put you to an "Acquiring Satellite" Message(Attention 015/535 message) and then download the guide (Attention 330). Check it then. If it still doesn't work, the box may need replacing. If it works, you are all done! Hope this helps!
Sep 23, 2010 | DISH Network DVR-625 DTV Receiver /...
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Jan 22, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Ok.. the remote has been set to my tv and cuts it on and off. the volume works but when i select the SAT button it does not bring up the menu schedule to browse the channels? The tv I'm trying to figure...
Hey there, Cheri Torres with DISH Network Customer Service.I came across your post recently and wanted to see if I could help. It soundslike your remote is going to need to be readdressed to the DISH Networkreceiver box. You will first need to take your TV2 remote to the TV1 location.I will list here for you the steps on readdressing the DISH Network remotecontrol. I hope you find these instructions useful and if you have any furtherquestions or concerns feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.:)
Instructions for addressing the remote to the receiver.
  1. Go to System Info screen. You can do this by either pressing the system info button on the front of the receiver box or by pressing the power button then press the channel up button once.
  2. Once you are in the system info screen you will see primary remote address(TV1) and secondary remote address(TV2). For your particular scenario you will want to change the secondary remote address number.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Jan 02, 2010 | DISH Network 135899 Remote Control
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Hi,my brand new UHF remote wont operate the #2 tv??
Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
Yamaha HTR-6030 Receiver Logo
91 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
