Question about Lexmark E234 Laser Printer
No paper fed
I dont know why the printer is keep saying that there is no paper. i dont understand what the problem... i already put a paper in the tray
  • kilowatt76 Apr 02, 2009
    There is paper in the paper tray. The printer will not pick up paper from the tray. If I manually hold down the red lever on the bottom left it works every time. Gears stripped?
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Posted on Jun 01, 2009
Thank you very much..
i just put papare un the printer
Posted on Jul 28, 2008
Trying to print on clear pvc keeps acting like no card is there says card not fed , i put in non clear and prints just fine
Go to the printer driver setup screen and choose clear . The paper out sensor will then be bypassed and the printer will pick up the clear sheets.
Mar 12, 2016 | Office Equipment & Supplies
Keeps saying paper jam,but no paper jam is inside
The jam indication is set because the sensor(s) detect one. This could be due to a buildup of paper dust, a small bit of a sheet that tore off and got lodged deep inside when removing a previous jam, or damage to the sensors if the jam was removed forcibly by pulling the sheets out from the wrong direction.
Dec 10, 2015 | Brother DCP-7020 All-In-One Laser Printer
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
C4680 All-In-One Inkjet Printer: paper won't fed and nothing prints...
Hi, i dont know you've got the same problem as i did. But i tell you how i fixed my problem. My printer said i ran out of paper, but there's plenty of paper where it should be. What i did to fix it was that i pulled some paper (remove the gray back plastic, turn pinter around, you can see the rubber rollers now) futher out and then placed the gray plastic back. Put the printer off and on the paper comes out. Then again off and on, then go rpint of copy something and it works again. I hope you it does the trick for your problem.
May 16, 2010 | HP C4680 All-In-One Inkjet Printer
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
The printer keeps saying No paper fed.
the paper sensor is dirty or something is blocking it
Oct 19, 2009 | Brother DCP 115C All-In-One InkJet Printer
Cannon ip 1800 printer
hi, your paper feeder might be jammed, try seeing if your little wheels turn properly (where the paper is fed) let me know..
Sep 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Paper feedin
The price of labor and repair parts could exceed the cost of a new printer in some cases. This most likely wouldn't be something you might be able to repair yourself. I would call the authorized repair center in your area and ask about a quote on what it might cost to repair this printer.
Jan 15, 2008 | Brother MFC-5860CN InkJet Printer
Lexmark E234 Laser Printer Logo
377 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
