Toshiba SatelliteM35-S320 (PSM30U7100QV) PC Notebook Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had bluetooth support when I got the my laptop new, I turned it off since I never used it. I would now like to turn it back on but the system says it can not find the driver. According to Speccy, I have a PSM30U-7100QV Motherboard with Toshiba v1.50 BIOS and an Intel Pentium M 1500MHz Banias processor.
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240219
Points
2570
Use the original bluetooth driver
How to activate bluetooth in a leptop
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
My bluetooth adapter is not working what i can do
For most dell laptops in order for the bluetooth to work you would have to turn on the wireless on your computer. if this does not work try to uninstall the driver then reload it back to your system then try to synch it with any bluetooth capable device. if it still does not work you can try to use a bluetooth USB dongle
Where is the switch that turns my bluetooth on and off
On some laptops the switch used to disable WiFi also disables bluetooth. If that's not the case for you, you can turn bluetooth off by simply right clicking on the bluetooth icon in the System Tray (next to the clock on the Start bar) and clicking "Turn Adapter Off"
I can not connect to samsung mobile to my laptops by bluetooth why
ensure you have installed bluetooth driver, turn it on, on the right below corner taskbar should appear bluetooth icon, right click it then add device, turn on your mobile bluetooth, the laptop should search for new bluetooth device, enter the passkey when given by laptop on your mobile, wait for awhile for adding new services
Good luck
3helpful
My Laptop's Bluetooth Won't Turn On. I Push FN + F6 (Which Is To Turn On Bluetooth) And It Doesn't Work. It Just Keeps Telling Me Bluetooth Off. My System Information Says This Driver Is Off. Any Help...
Which model laptop is this? Many of the Gateway laptops have 2 switches for the Bluetooth. There is a physical switch on the front or side of the system that needs to be turned on for both the wireless LAN and the Bluetooth to work.
The physical switch needs to be in the ON position, then you can use the FN-F6 to toggle the bluetooth specifically on and off. Depending on the model there will be another toggle, possible FN-F2 to toggle the wireless Lan on and off once the switch is turned on.
2answers
Bluetooth is not working in Lenovo 3000 y500 notebook
Uninstall the WLAN Bluetooth driver from the system properly and restart the system and after restarting the system then reinstall the driver properly and restart the system again and after starting the system then check
Bluetooth mouse won't work
whe u installed you mouse, you installed it from the cd from targus..right? so there is some settings in that program that you can change so when you turn on your laptop the bluetooth seeks for bluetooth items and it will find your mouse. I know its a little bit tricky but you can fix it, find the settings, change them and you dont have to buy a new mouse.
When you turn of your laptop the cooonnection betwen the item is lost, when you turn on you laptop i asume that your bluetooth is now passive, by making it active it starts immediately search for bluetooht items.
Bluetooth iogear adapter
My Toshiba Laptop was setup to create automatic "System Restore Points"...I simply went back to the system restore point one day prior to installing the Iogear Bluetooth software: (my computer>accessories>toshiba tools>system restore).
I now have my Windows XP Welcome Screen back - -any changes or program installations I've made after the restore date will need to be reinstalled or reapplied, but I didn't have much on the laptop anyway, since I had just got it!
I would suggest backing up any files or data you may want to save before doing the system restore on any computer (maybe on a flashdrive or sd card, someplace other than the harddrive - then you can select what you want to install - excluding the culprit that caused you the problem). The system restore option will backup certain system files - notifying you of the new filenames after the restore has completed.
If the system restore process doesn't work, you do have the option of 'going back' to the last system settings, or trying another 'System Restore Point'.
If any desktop or laptop pc has a 'System Restore' option, I highly recommend turning this feature on....it may prevent a lot of headaches and problems!
One suggestion - BACKUP your system somewhere before making any major changes to your system...especially before installing new applications, or even before changing your system profiles or connectivity options...so many things can't easily be 'undone' !
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
