The lid on my laptop can no longer stand up? How do I fix it?
  • 101 Answers
Call to call center from laptop product services you can get the direction
Posted on Jul 23, 2008
Buttons work, but the safety feature wont let it run unless I lean on the lid
Don't know if it's a front loader or a top loader. Either way, there is a safety switch in the lid. On a top loader, there is a little button at the back of the lid opening, which the lid pushes as it closes. the lid may be out of line, or warped. Did anybody stand on the lid ? If bent, try to twist the lid straight. You may also try temporarily wedging a folded matchbook cover between the lid and button until you can fix it correctly.
Mar 07, 2015 | Washing Machines
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Lid switch shorting somewhere. In this model there is no pin that I can ses. But after removing bezel it flickers but I need the location of the lid switch to check. When opening lid slowly it sometimes...
Probably not a lid switch related problem. In the more modern Toshiba's, the lid-close switch is generally located either above the keyboard area or underneath the front end of the palmrest (towards you), and the lid-close function is activated by a magnet located either above or below the screen. Best way to check if the lid-close function is working properly is to use Toshiba's power management to set the system to go to either stand-by or hibernation upon lid-close - and if the computer goes to stand-by or hibernation when you shut the lid, then that part is functioning properly.
A better, more detailed and precise description of the problem with the screen will probably help in addressing the real problem.
Sep 20, 2011 | Toshiba Satellite P205-S6237 Notebook
I have an Acer aspire 5103 and the lid lock is loose and no longer locks. Can I fix this myself? Nothing appears broken, but it feels as though the spring mechanism inside the lid has gone. Does it have to...
yes it has to be repaired professionally to avoid damage to you notebook, if your not sure on what to do dont do it, you might just damage your unit. have it fix by a experience tech, paying a little could save a lot
Nov 26, 2009 | Acer Aspire 5100 Notebook
Dell C840 won't stand-by when closed.
yes this sounds like a hardware problem the switch is not telling your laptop that the lid is closed you might want to take this to a computer tech and have them change it
Dec 21, 2008 | Dell Latitude C840 Notebook
Trunk and hood manual latch won't work
That is not the problem the problem is your convertable roof is not closing properly to test this let someone press down on the roof lid and then try to open the trunk, To fix this let the roof lid open and let the roof come up until the back part stands up to let the roof lid close so that the roof hold is exposed look on the right hand side of the car (if your standing at the back) under the roof lid catch there is a small plastic buttun that the roof lid catch needs to pres down on, this tells the car that the roof lid is seucre and it is now safe to let open the trunk, All you have to do is set the tension on the cable for that roof lid catch and the problem is sorted.
Beamerguy
Sep 03, 2008 | 1997 BMW 328
Software problem
Does this happen every time you download something from the internet?
Has the computer turned itself off while doing anything else?
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
740549c.jpgBased on own preference, it’s possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  1. Click OK button.
How to Disable Notebook Computer to Stand By or Hibernate on Closing Lid in Windows XP
  1. Log on to your computer as an administrator. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
e461aeb.gifAgain, any other settings such as Stand by and Hibernate can be set based on own preference.
  1. Click OK button.
Let me know if this helps - if not - PLEASE, further clairify so we can continue to find a fix for your problem....
Jul 22, 2008 | Computers & Internet
10 minutes of background processing when coming out of stand-by...What is going on
Click Start, Run, type msconfig. Click the startup tab. There will be a list of all the programs that start up when your computer starts. You should uncheck everything you don't need. Pretty much everything except antivirus.
Sep 11, 2007 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
