Question about Danby Refrigerators
I have a Danby DCR120BLWEY compact refrigerator and the overload protector was fried by lightning. I have been trying to replace this part (#432.44)and cannot locate it, even directly through Danby (on hold for over 1 hour). I'm desperate. Don't want to trash a perfectly good refrigerator for the lack of a small part. Can you help?
aborcass
  • 2651 Answers
SOURCE: Overload Protector
i guess you can ohm it out witha meter( exact specs idont know) can you hear it clicking on/off??, generally i remove it from compressor and if its faulty it shake and sound busted. might be bad compreesot that coaused that (which should be covered under 5 yr manu. warr) adnthat comes with new overload protector
Posted on Mar 01, 2008
SOURCE: Oster Compact Refrigerator Model OR4505G3B
Oster 4.5 Cu Ft Compact Refrigerator OR4505G3B
I just bought it from bestbuys for $99. It does get really hot when I have the setting on high, but it is still warm when i have it at 1/2 power...warmer than I would like it to be. I connect it straight to the wall outlet.
The temp. may be higher due to ambient temps.
The frige came with messed up box, paint defects...so I thought that it was a decfect/return...but I guess it may be normal for it to get so hot.
Posted on Sep 04, 2008
  • 27 Answers
SOURCE: danby freezes all beverages
check position of thermistat bulb it should be on the plate
Posted on Jul 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: I just brought home a DCR038W Danby compact refrigerator.
Yes, wait a whole day to let the compressor oil dran back to the compressor.
Posted on Sep 04, 2009
heatman101
  • 43501 Answers
SOURCE: Danby DCR412BLS compact refrigerator stopped
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 21, 2010
TV no power.Cable hit by lightning.
if didnt have a surge protector and unit took a lightning hit more than likely unit totally fried
Jul 31, 2016 | Televison & Video
Tip
Surge protector for refrigerator power
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair (refrigerator fan and main board). The board that was replaced actually had a burn mark on it where one of the components had fried.
Standard computer plug strip surge protectors may not be large enough for a refrigerator load. I used a plug-in surge protector that is made for use in offices for copiers and large printers since it has the capacity to handle a refrigerator load. Make sure it is one that does not cut off power so the refrigerator will continue to operate if the protector is overloaded or fails.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Replace door gasket on danby dcr412 compact refrigerator
Hi There,
I'm not sure what you are asking here, however if you are looking to purchase a replacement gasket for this model you can contact the Danby parts department at 1- 800-496-6049
Thanks!
Aug 01, 2012 | Danby DCR412 Compact Refrigerator
Danby kegerator at 50 degrees. Won't cool. Compressor?
How To Test the Compressor Relay Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor. Remove the compressor relay by pulling it straight off from the compressor.Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. bobicehouse_31.jpgThere are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Jul 14, 2011 | Danby DKC645BLS Compact Beverage Cooler
My refrigerator stopped working because I left the door open for like three hours and the electricity does not go to all the fridge parts like the lighting system is off and the freezer is off every thing...
There is no sensor like you stated. Actually, when you keep open the fridge door, the cooling all will go out and hence thermostat sensor would not cut off, as required temp not reached inside the fridge.
So, the compressor would have run for long time without cut off. Due to this the overload protector trips the compressor. Remove power for 4 to 6 hrs. And then restart the fridge. But make sure you close the fridge door. Thanks.
Mar 20, 2011 | Danby Compact Refrigerator DCR-101W
Sounds like overload protector issues. cuts in briefly and cuts out.
touch the compressor if its red hot its knackered sorry to say.... needs regas ..
Feb 25, 2011 | Danby Refrigerators
Sep 04, 2009 | Danby (DAR604BLS) Refrigerator
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
Apr 09, 2009 | Danby DAR482BLS Compact Refrigerator
Refrigerators Logo
331 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
