Question about Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m (Verizon)
My phone seems to be stuck at the startup screen. After I turn it on, the keys intermittenly respond but I cannot make calls or even access menus. This all happened when I did a master reset. The Verizon folks said that should not have affected the phones operation. Duh! But here I am. Will reflashing the phone help, Can it be re flashed? Thanks for any help you can provide.
Randy
  • Ruth Fleming Apr 01, 2009
    I have the same problem exactly as you describe except that I did nothing to it prior to this happening. I have search the web and flashing is the only recommendation I see. Phone is not under warranty. Where can I get it flashed?
2 Suggested Answers
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do i do a factory reset on a verizon motorola 4glte model xt912 or remove the password somebody else put on the phone that' i obviously dont know or have
    Hi Naden Puttock,
    Here are the steps to perform a hard reset in your device:
    1. Switch off the device.
    2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
    3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
    4. When you see Android with triangle, then press together Volume Up + Volume Down.
    5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
    6. Choose option "Yes -- delete all user data" and accept with Power button.
    7.
    Press Power button to select option "reboot system now".
    Best Regards,
    Katy
    Motorola Support
    Posted on May 18, 2015
    Motorola Razr flip phone stuck on contacts, right arrow key won't work. I turned phone off & removed battery & still won't work
    Hi Anne,
    In that case you will need to perform an FDR (Factory Data Reset), How do reset my DROID RAZR here you will find the steps to do that.
    Regards,
    Maya
    Motorola Support
    Jul 17, 2016 | Motorola Mobility Lot Of 3 Razr V3c V3m...
    Can't synchronize my motorola v3m with the PC
    The only way to sync is if you have the sd card in,and you can only sync the sd card, if you did not have verizon,you could use motorola phone tools and sync everything, but verizon turned off transfer
    in your phone because there thieves, but if you learn how to hack a razor you can use moto phone tools.
    Dec 30, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Stuck in airplane mode
    try a master reset of the phone...or tyake the phone adn have the flexcable replaced.
    Nov 22, 2008 | Motorola Mobility RAZR V3
    Verizon razr v3m freeze
    That is a software issue. You need to either contact motorola or verizon regarding that issue. This is a known problem with their phone and they never fully resolved the first batch of the Razor freezing issue.
    Sep 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Motorola Razr V3m external display
    go to menu, settings and tools, call settings, answer options and set to "any key" and you should be able to open and see who calls and then hit any key to answer phone, Hope that helps, doesn't solve problem with broken screen, but doesn't answer phone if you don't want to talk to person calling.
    Apr 23, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Razr v3m text problem
    Have you done any modding to the phone and is it still under warranty?
    Also who is it through? Provider?
    Mar 19, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Motorola Razer V3M Won't start
    It may be a software problem. Similar thing happened to my LG Chocolate from Verizon. I found out that certain Verizon stores can perform an update on certain phones. Maybe Sprint has a similar software update. You can call your service provider and ask.
    Dec 09, 2007 | Motorola Mobility RAZR V3m Cellular Phone
    I cant use blutooth to transfer files to other mobiles
    My friend, Verizon is the worst company that makes bluetooth useless, The reason why this is? is because Verizon has its V cast music going, so they disable verizon phones to be able to transfer music or pictures phone to phone via blue tooth, this sucks i know, i dont think u can even put music using motorola phone tools as verizon phones has a totally different interface,
    Dec 05, 2007 | Motorola Mobility RAZR V3m Cellular Phone
    Razr V3M Power-up/Black Screen
    I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
    Oct 16, 2007 | Motorola Mobility RAZR V3m Cellular Phone
    Motorola Mobility RAZR V3m Cellular Phone Logo
    151 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
