Question about Insignia 37" LCD Flat-Panel HDTV
Blue Shadows Why would this tv all of a sudden start displaying blue shadows not only in the black parts of the screen, but also in the part of the screen that is actually showing the picture? The shadows are usually the person's head which radiates up to the black part of the screen. For example, you are watching a movie, and the ratio is 16:9 and you have a top and bottom part of the screen that's black right? Well, that is where these shadows appear, and now it just started displaying those shadows in the white areas of the picture. So what is going on?
  • Anonymous Jan 24, 2009
    I will give that a shot. I'm really disappointed though, considering this is a brand new set, and definitely not cheap. I wanted to get this for my family, since we watch alot of movies and play games with the XBox 360, and it does have a beautiful picture for the money involved. I hope this works, since I really dont want to be without a tv while they tinker with it. Thanks...
We have a 47 inch Vizio, Blue shadows
my vizio made a popping noise and then screen went black. tv has power
Aug 30, 2009 | Televison & Video
My hitachi tv model 43fdx15b has a blue shadow
I tmay be your graphics card, but I would try and adjust your display via the Display Options probebly located somewhere on your Games Start Menu.
But like I say, it might just be your graphics.
I hope this helps.
Jul 08, 2009 | Blue Byte Software Battle Isle 2220:...
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows & black screen with flashing red light
Your problem is the convergence IC's (part number STK392-110). They will need to be replaced as well as matbe a couple of burned resistors that will be right by the IC's. Due to the complexity of this repair as well as the alignment required after the parts are replaced. you may want to contact a tech. Let em know if I can be of further assistance. You can find a local tech by going to the homepage of FIXYA and inputting your zip.
Dec 22, 2008 | Televison & Video
Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Nov 03, 2008 | Televison & Video
Problems with my Mitsubishi hd1080
If the Blue lines are blurs or shadows, then your Convergence IC's are going or gone bad.
I have the same TV - it will be 4yrs. old in Dec. Mine started with Blue lines & shadows, then Red, Blue, Green Shadows. This is caused from over heating. The Convergence IC's have to be replaced.
I have had 3 TV Repair shops all quote me a price from $350. to $400. to repair. They all said 4 years is the usual life time for these IC's.
Replace the STK932-110amps with STK394-250-E or STK392-150 for greater reliability.
Use only Original Replacement Parts, there are some cheaper but won't last and can't take the heat.
If you are a "do-it-yourselfer" here is a link with the directions and pics.
Good Luck!
Mar 19, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hit 53UWX10BA
convergance ic bad
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Insignia 37" LCD Flat-Panel HDTV Logo
343 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
