Do we have to manually set the pix set key for every station/show we watch? We loose scrolling writing at the top and bottom of the screen on my dad's new 32" lcd tv bought at Wal-mart. When we set the picture to display wide format, heads and bodies of people do not look "Normal". We are hooked up to Verizon FIOS HD turner and all of the above seem to happen no matter if on a HD channel or regular broadcast channel/
Thanks for the offer but we cannot afford to pay additional money for something the Factory support service Should provide.
From what we have heard through the Verizon installer, our SANYO LCD TV probably does NOT have a Automatic picture adjust system. That would most likely be the reason for the maunual button on the remote control. The troublle is that with the FIOS service, you do NOT use the TV's remote control. That leaves to switching back and forth between two different remotes wiich can be vary confusing for someone that is not 88 years old.
It is bad enough that you have to remember which channels you have to go to to receive HD programming signals. If I were making a TV set, and or running a TV network/ cable service, I would transmit both HD and regular signals on the same channel number and let the TV and or the decoder box figure out if my set could display High Definition. Isn't that what we spend lots of money buying equipment and paying each month for service?
If anyone out there knows if the SANYO 32 inch LCD TV sold at Wal-Mart automatically adjust to the picute format, (PIX 1-4) we sure ould like to hear from you.
Posted on Jul 24, 2008
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
Apr 26, 2012 | Polar FT4 Watch
How do you set the time and date for a pokemon c watch form trend setters?
you press down on the two buttons on the right as hard as you can until it shows the time settings. It took me a long time to figure it out but i was super excited once I got to set mine xD Hope that helps!
Jan 04, 2011 | Watches
I have a Panasonic PT-53wx54 HDTV. The text on the ticker on the bottom of the screen that stations like CNN run is not completely visible, only the top of the letters show as they travel across the...
The set is probably in the wrong display format for the channels you are watching. Look through the setup menus for "Display format" or "Display mode". You need the menu that sets the picture for "480i", "720p", "1080p", etc. Set it for 1080p and see if that fixes it. The lower settings won't show all of the lines for a 1080p picture; they are used for old-style analog video or low-bandwidth broadcasts.
Disclaimer: this is general information and may not apply exactly to your particular model. You may still have to find your owner's manual or download a copy to find out how to correct the settings.
Oct 06, 2010 | Televison & Video
How to set pokemon c wrist watch?
Hold down the two right buttons. A screen will eventually appear showing the watch's current time with the hour number flashing. Use the top right button to scroll through the numbers, and push the bottom right button to set the number. After you set the time, then the date screen will show with the watch's current date, with the month number flashing. Same buttons do the same thing here.
Sep 30, 2010 | Watches
Instructions for pokemon 'c watch' talking watch
Aug 17, 2010 | Bulova Watch
Station name
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key. (or the clear key to erase)
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Jan 20, 2010 | NorStar T7316E Corded Phone
Picture is cut off when watching hd stations on my sanyo 42 inch hdtv
You can't fix this problem using "pix shape" on the TV itself. To fix this common problem, just change the format on your SAT. BOX using your sat. remote; It should have a format button it. Just keep pushing the format button till you get the whole picture to show on screen and you should be set ...
Nov 28, 2009 | Sanyo Televison & Video
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Picture too big for screen
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
Just got digital hd
If you press the zoom- button on your remote it will give you options for the screen size. The "stretch" option might help.
Oct 17, 2007 | RCA L26W11 26 in. HD-Ready LCD Television
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
