Question about Amana Refrigerators
ARB1914CW AMANA REFRIGERATOR. FREEZER PART SEEMS TO BE WORKING FINE BUT THE FRIGE SECTION IS NOT. TEMPERATURE IS STARTING TO RISE IN THAT SECTION AND TURNING THE THERMOSTAT UP HIGHER DOES NOT EVEN TURN THE UNIT ON. ANY SUGGESTIONS?
  • bill9770 Jul 23, 2008
    Condenser coils were cleaned two months ago and look to be still quite clean. The unit has power as the inside lights work.
    Brigadier General:
  • 6,966 Answers
Please check the fan that blows cold air from the freezer through the vents toward the refrigerator section. Open the door, press on the door switch, wait for a minute or more, the fan should kick in. If not defective, corroded or frozen.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 23, 2008
    Genius:
  • 1,447 Answers
Hi
you might have a dirty condenser. Models equipped with a fan in the compressor area will need to have the condenser cleaned on a periodic basis. As the condenser collects dirt and dust the refrigerator will run longer.
Here's how to do it:
1) Pull the refrigerator away from the wall, and unplug it. Or, if it's a built-in model, turn off its circuit breaker.
2) Remove the cover panel to reveal the coils. On most models, the kick plate or top trim plate simply lifts off. You may have to remove a few screws to remove a back cover.
3) With a long, narrow nozzle on your vacuum, clean out all of the dust and debris. (At an appliance parts store, you can buy a special long-handled brush that looks somewhat like a bottle brush for this job.)
4) Replace the cover, and then plug the electrical cord back in or turn the circuit back on.
As a rule, refrigerators are the most dependable of all large appliances. Even so, they do fail to do their jobs adequately on occasion, and when they do, the results can be disastrous because expensive food can spoil in a hurry.
Again these are the things that you should check, because
Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the refrigerator should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all. Call a repairperson.
Thanks for using Fixya
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 23, 2008
    Hi-
    Check the fans if its running, if not chances are you need to have your refrigerator service, if its within warranty call your manufacturer for home service.
    Genius:
  • 3,422 Answers
HI,
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
  • Priya darshan Jul 23, 2008
    If you are unable to troubleshoot the problem from here, you will have to contact a qualified appliance repair technician.
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
May 11, 2011 | Amana ABB2227DE Bottom Freezer...
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana Refrigerators
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
Amana refridgerator temperature rising, especially freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 27, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer not working
the symptoms you describe, freezer temperature rising while the fresh food section "seemed" ok, my guess is by the time you read my response, the fresh food side will be just as warm as the freezer. when the cooling pattern is similar to this, it has to do with the compressor no longer running. the compressor itself may be ok, instead the starter has failed, but i would not recommend you even attempt this yourself, as you can cause permanent damage to your compressor, property damage to your home, or electrocution hazards to your self. I would highly recommend you have a reliable refrigerator repair service at least inspect it for you.
Apr 02, 2010 | Amana ARS2464B Side by Side Refrigerator
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Jul 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
290 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
