Question about Toshiba DKT 3010 Corded Phone
Long Distance Block
One of my handsets is blocked for long distance calls. We have free long distance now and need to take that block off, but the tech company wants to charge me $95 to do it. Is it something I can do?
    Scholar:
  • 108 Answers
Unfortunately you have to access the system programming to do the changes and I'm sure your tech company has a secure password on the system.
Posted on Jul 28, 2008
CAN i STOP MY DAUGHTER FROM MAKING LONG DISTANCE CALLS FROM MY MAGIC JACK GO?
sure take the magic jack out of your system and keep it on your person at all times
Nov 05, 2015 | Cell Phones
I need to transport a front loading washing machine a 3 miles distance. I know that front loaders require a stabilization kit, but given the short distance, is it really necessary?
with the machine unpluged and freestanding from the wall.at the back of the top panel you will find two screws remove and slide the top off,you see a large cement block get an old duvou/heavy blanket and wrap it inside over the block and top of machine,keeping the drum and block as tight as possiable.dont forget to remove after moving.adrianxxx
Apr 02, 2013 | Kenmore 44072 Front Load Washer
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
I need to know how to stop blocking outgoing long distance calls in T7316E
You would have to call the phone company and have them block long distance calls.
Mar 08, 2011 | NorStar T7316E Corded Phone
Can't dial long distance from one phone
Sounds like that station is programmed to restrict certain digits (like 1 in the prefix) -- this is usually done by the tech because the owner doesn't want unauthorized calls to take place from a publicly accessible phone. To confirm this, swap the phone with another identical working phone and see if it's still restricted. Good luck!
Jan 29, 2009 | Samsung Phone PDCSLCD12B
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Partner 18 phone has long distance blocked
There are a bunch of ways to accomplish this.
FIRST. When you say you cant dial long distance. What happens when you do? Do you get an error tone from the phone system? Or do you get a recording saying you cant dial long distance?
If you get an error tone, there are still a few ways to make this happen, so report back.
Nov 14, 2008 | Lucent PARTNER18 Corded Phone
I can't make long distance call?
Is this a recording, or does the phone display this ?
If this is a recording, it is from the long distance provider. Did you change long distance companies lately?
Call your long distance company....this is their fault.
Nov 13, 2008 | NorStar Meridian M7310 Phone
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Restricting long distance
in system programming you will need to restrict phones to localcalls only
Feb 01, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Toshiba DKT 3010 Corded Phone Logo
322 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
