Question about HP OfficeJet 6210 All-In-One InkJet Printer
Paper wont load
Keeps saying out of paper but when i put the paper in i hear the feader moving but no paper goes in
  • 446 Answers
Chances are the feed roller are dirty, overtime they can get soiled and slip, pls clean with moistened cloth gently and try again
Posted on Jul 24, 2008
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Paper gets jam
check the paper feader ... and check the gear of paper feader...
Nov 11, 2010 | Epson LX 1170 Matrix Printer
My printer wont pick up paper , it keeps saying load paper and press okay when clearly i have paper at the bottom
Try to put paper in the manual feedd tray. If it prints, then put more paper in the auto-load tray, if that doesn't work, check the EXACT location of the clips and position indicators that indicate what size of paper is inthe tray. They may have moved, just slightly out of alignment. That has happened to me. Other than that, it may need new pick-up rollers.
Hope that helps.
Sep 16, 2010 | Office Equipment & Supplies
A line appears when photocopying
Check the glass for a piece or dirt. When you use the doc feader it runs the paper over the scanner instead of the scanner running over the paper when you put it on the glass. There should be a strip of glass that the doc feader uses. A small piece of white out can make a line. If the line apears when you place a piece of paper on the glass then it is your photo drum and you will need to replace the tonor cartrage,
Hope this helps
Sep 15, 2009 | HP LaserJet 3030 All-In-One Printer
Printer alignment
you have little sliders on the side where the paper goes in ..move those
Jul 09, 2009 | Office Equipment & Supplies
Canon Mx300 wont recognize my paper. says:load paper
I cant light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Epson stylus C43UX. my printer keeps saying paper jam and paper not loaded correctly and just spills out the paper i load. the paper is loaded perfectly but it just wont print! the stupid red light just...
The printer reports a paper jam because the paper feed system cannot feed paper.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
Mar 27, 2009 | Epson Stylus C43UX InkJet Printer
Konica Minolta Bizhub 920
You need to set machine for extra cassette.
Nov 23, 2008 | Konica Minolta Di1610 Copier
Saying no paper,. even when it's fully loaded & wont print.
i just thought i had the same problem... but you know how there are 2 buttons on the front of the printer once the paper output tray is down? the bottom of those 2 i think switches it back and forth between paper feeding from the normal, top spot, and from somewhere else, so you can try pushing that button! worked for me!
Oct 11, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
