Error window appears that reads "Can't find resource file". This happens at every restart of Windows.
  • 300 Answers
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Thanks
Posted on Jul 23, 2008
  • S C Jul 27, 2008
    Once you get rid if the problem file, you can run msconfig again and choose Normal Mode and click OK. You will be prompted to restart. This will cause it to load any additional programs that started previously.
    Thanks
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
When i start my Cybercafe PRO Server it gives an error messge " Port: 15346 appears to be blocked. Can somebody help me how i can open this port?
1. Find your host file located in your windows folder.
WinXP = C:\Windows\System32\Drivers\Etc\hosts
if you cant find the host file, please go to your folder options and UNTICK "hide protected operating system files"
2. After locating the hosts file, right click it, properties, UNTICK read only if it is read only to make sure we can edit it.
- open the host file with notepad and write like this:
127.0.0.1 sync.oneroof.com
127.0.0.1 reports.oneroof.com
- after done, save it/overwrite.
3. Please restart your PC and try your CCP Server again.
Aug 30, 2011 | Computers & Internet
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
Run-time error'75' path/file access error .This keeps comming up trying to program XE-A203
Cause of the Error
This error message is generated only on a Windows computer when a read-only shared resource has share-level access control.
Resolution Methods
You can resolve this issue by using one of the following methods:
*Change the access permission on your shared resource from read-only to full control.
*If your Windows computer is in a Windows NT domain, you may use user level access to workaround the problem.
*You may use Win32 API calls to access your read-only shared resource on Windows.
Dec 01, 2009 | Casio Parts Cash Register PC Desktop
I have a BRAND NEW HP Pavilion Notebook which I just switched on for the FIRST time. It has come up with an error message, ie: "The computer restarted unexpectedly or encountered an unexpected error....
Your windows installation CD might have become corrupt. Use a fresh CD and enter into BIOS settings to set Default Settings before installation.
Try & reply.
Sep 11, 2008 | HP Computers & Internet
Computers & Internet Logo
David Payne
David Payne
