Question about IBM Wheelwriter 30 Typewriter
IBM wheelwriter Hi,,,Ribbon drive gear is going around but the hammer is not moving to strike the wheel. Any ideas?
  • eliz231 Jul 24, 2008
    Thank you for your response. I see the rubber part and adjusted it here and there but it made no difference. I also see the spring and it is connected. The hammer does move freely by hand. Sounds like something is disconnected, right?
The hammer is not moving. the model is ibm 6746
Posted on Aug 18, 2008
  • 73 Answers
Dickyo is exactly right. The solenoid pad for the print hammer is deteriorated. A tech can replace it with a new hard nylon one that will last for years.
Posted on Aug 08, 2008
  • IBM Master
  • 3,594 Answers
You didn't say what make or model this is. If it is an IBM wheelwriter there is a good chance the print solenoid cap is broken.
DickyO
Posted on Jul 31, 2008
    Sergeant:
  • 329 Answers
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Posted on Jul 23, 2008
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
The print wheel strikes the paper but bypass the ribbon. Makes a good impression. I've adjusted everything I can. Where do I go from here. It's a very good typewriter - in excellent condition.
The older WWs have a black plastic gear on the R. side of the carrier, they get tooth for tooth, wiggle it, it should move easily with the power off.
DickyO
Oct 18, 2010 | IBM Wheelwriter 6 Typewriter
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
IBM wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can, but to no good.
there is a solenoid that fires the hammer to strike ribbon and that most likely is the culprit. sometimes, you can clean solenoid and replace the little plunger to take care of the problem. however, it takes a tech or at least someone with very good mechanical skills to get to it.
good luck,
razors
Mar 16, 2010 | Office Equipment & Supplies
I need a manual for IBM wheelwriter. Is there one
Go to LEXMARK.COM and click your way to publications you will find a downloadable manual there.
If the hammer isn't striking the paper the print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Jan 24, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
The hammer does not strike on the platen
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Apr 08, 2009 | IBM Office Equipment & Supplies
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5
Get a new laser printer, or even inkjet. They can be had for under a hundred bucks. It'll cost you that to get someone old enough to know what a wheelwriter is to come and look it...
Jan 08, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 30 Typewriter Logo
449 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
