Question about Video Game Consoles & Games
I get code p0871 in my jeep liberty 2002my
Trans in limp in due code p0871
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
Try posting your question in the automotive section, you will get a better response.
Posted on Jul 31, 2008
Luz marcada con el numero cinco?
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ...
? 1:13
https://www.youtube.com/watch?v=pGrPBBzp7wE
Jan 6, 2013 - Uploaded by DeathScouter
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ..... error code will flash 2 times, brief pause, flash 1 time, pause, flash 5times, pause, ...
2005 Jeep Liberty possible cause of P0442 error. - YouTube
? 5:26
https://www.youtube.com/watch?v=2ba-gH0gadg
Dec 21, 2014 - Uploaded by TheBGravit
While replacing a bad fuel pump I believe I found the cause of a P0442 Error code. I was able to repair the ...
Jeep Liberty Questions - Cylinder Misfire code - CarGurus
www.cargurus.com > Questions > Jeep > Liberty
CarGurusMay 27, 2009 - My jeep Liberty 2009 does the same the Dashboard showed a code of cylinder .... i have a jeep liberty 2006 with the # 5 cylinder misfire. i replaced the sparks... I have a 2005 Jeep Liberty 6 cylinder, engine light came on scaned the ... 2002 jeep liberty camshaft posistion sensor error code p0340 5 answers.
Check Engine Light/Misfire Due to Intake Valve Locks ...
repairpal.com > Problems > Jeep > Liberty
Recently got a second hand 2005 Jeep Liberty Sport. Everything worked fine ... #5intake valve seat dropped and held open the intake valve. 2008 Jeep Liberty.
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected
www.obd-codes.com/p0305
Dec 08, 2015 | 2005 Jeep Liberty
MY JEEP LIBERTY WILL NOT SHIFT OUT OF LOW
wow no year stated, its 1996 and never but how new
its a KK or KJ jeep 2002 to now. 14 years of jeep.
as is what transmission used, and if 2wd or 4wd.????
first the p0700 code
ONLY, means
1: SCAN TOO you using is junk, and old,
or
2: means the TCM needs to be scanned by self. to see all codes in the TCM.
my guess is you need a real scantool..
700 means, trans has errors, stored, ASK IT NOW.
1: fuses good,
2: is TCM plugged, in? some Liberties have seperate PCM and TCM.
3: the TCM most see all sensors working (where ever it hides)
if not , it will not ever upshift.
speed sensors dead, or not plugged in?
PCM cant talk to TCM.// oops....
and more.
the problem is your tools, (missing a real jeep scan too)
my INNOVA 3160 can see those errors, but ive never done a liberty, in fact i don't consider it a real jeep.
The TCM is JUST a computer (a simple microprocessor)
it has inputs and outputs (shift solenoids)
if the inputs lie, it can not shift or shifts wrong, or goes to limp home and skips gears.
all TCM work like that, and not scanning it is a FAIL.
you must scan it fully. to get all CODES.
Dec 02, 2015 | Jeep Cars & Trucks
03jeep lbertyrandom missfire cyl 2 4 6check engine light flashing
Jeep Liberty Check Engine Light/Misfire Due to Intake Valve Locks/Valves. ...Misfire cyc 4 and random cyc misfires, changed coil packs and plugs... sounds as if rod ... Light came on again (misfire on cylinder 4) - switched coil from 4 to 2. Light ...
CarGurusMay 27, 2009 - #4 misfire new plugs and coil pack on #4 light came back on after 300 miles if ... How come it stopped misfiring for 2-3 months, and now is back? ... I have a 2005 Jeep Liberty 6 cylinder, engine light came on scaned the codes ...
Liberty Cylinder Misfire / Computer issue? - JeepForum.com
Nov 28, 2015 | Cars & Trucks
I have a 2004 Jeep liberty, and my car seems to be jerking and slowing down as if it wants to stop. The codes that I have are: P0700,P0441, P0870, P0871, P0733, P0734 and P0732. What do just do? How much...
Make sure the fluid level is correct and look at the color of the fluid. It should be bright red and not smell burnt. It could be as simple as changing the fluid and filter.
Mar 18, 2015 | 2004 Jeep Liberty
What is P0871?
PO871: Trans Fluid Pressure Sensor/Switch C Range/Performance.I bet this is an external sensor that can be replaced from the outside of the trans.(I didn't work on automatics at the dealer-we had 2 specialists that repaired automatic transmissions.You can see why I prefer 3 pedals under my dash!)
Sep 15, 2012 | 2003 Chrysler Concorde
My 2002 Jeep Liberty showing codes 0731, 0733, 0734 and P0871 - can this be repaired without getting new ******?
No,You need a rebuilt or new transmission,I see this in alot of Jeeps,Even if you maintained the transmission fluid and drove carefully,the transmission itself is a problems.
Mar 10, 2012 | 2002 Jeep Liberty
What does po871 mean on a 2002 jeep liberty
Definition of DTCP0871for All Makes Code: P0871 Category: Powertrain Definition: Transmission Fluid Pressure Sensor/Switch "C" Circuit Range/Performance
this could be low fluid level or a faulty sensor. Not easy to diagnose without seeing the vehicle.
Hope this helps..
Mar 26, 2011 | 2002 Jeep Liberty
2007 Jeep liberty auto trans will not shift from 2nd gear. Check engine light is on. How do I reset the light, check the codes? I know this is "limp mode".
YOU NEED TO HAVE TRANSMISSION CONTROL SYSTEM SCANNED..IT HAS DETECTED A PROBLEM IN THE ELECTRICAL SYSTEM,INTERNAL OF TRANS OR A SENSOR FOR TRANSMISSION..A TRANSMISSION IS AN EXPENSIVE COMPONENT..YOU SHOULD GET IT CHECKED ASAP..ESPECIALLY IF YOU HAVE NO WARRANTY LEFT
Jul 04, 2009 | Jeep Liberty Cars & Trucks
Video Game Consoles & Games Logo
557 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
