Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error 4, 2
Hello. I have a problem with mp160, display says e 4, 2. I have tried to reset with pressing power and reset combination , but when the printer will go in service mode i don't know how to reset because when orange and green lights are blinking reset button doesn't work.
  • 4,889 Answers
WHen the lights blink you should press and hold power button and then press reset. Did you read my earlier solution? If you do it correctly it should work. Trust me i have done it quite a few times.
Posted on Jul 24, 2008
I am trying to print and my Canon MP160 is flashing 2 and E. I cannot print what can I do
This is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
YOU CAN TRY THIS:
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope this helps,
Good Luck
Mar 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Conon mp160 e5 error
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Apr 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP160 error code 2 E blinking alternately; also get Service Error 5100. I cleared out a pencil from the paper feed area and replaced a loose spring, but still get 2 E error when I try to print
Press the <Black> or <Color> button to clear the error. If unsuccessful and printer is not functioning properly you may need to reset it:
1) Press and hold <On/Off> for one second. Display will go blank. (If this does not happen, unplug the printer).
2) Wait approx. 10 seconds
3) Plug in the device - Press <On/Off> if necessary to power on the printer
4) Wait until the device has finished its startup routine
If the problem still persists, your MP160 may need servicing by a qualified technician.
Dec 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon pixma mp160 and the ink absorber is full. It is showing an error 8 on the lcd display. how do i fix it?
follow this steps to fix this error.
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
The number of the Reset button pressing LED Function Remarks
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Sep 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MY MP160 FLASHES E AND # 3 ALTERNATELY
E2-2 No paper (ASF)
E3-3 Paper jam
button pressing
procedures below.
procedures below.
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 error E42
Hello there ok
it.
procedure:
button pressing
the "service mode"
Try it
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My problem with my pixma 145 is there is an error "ink absorber i
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Mar 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP160 error message E5 and alarm light on
OK lets try this
Also if you are using the Refillable ink cartilages stop they always cause major issues
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.(it must be turn off)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
Oct 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
PIXMA MP160
cartridge cannot detect by my printer canon pixma MP160
Jul 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
cropp
Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
