Maytag PAV3240A Top Load Washer Logo
Pamela Bates Posted on Jun 14, 2017
My top load Maytag is dripping water after the whole cycle completes. I removed the inlet valve, directly hooked up the hose to each bib on the valve, turned the water shutoff on and nothing leaked(turned valve upside down). Reinstalled it and it still leaks. Even after I turn the water shutoff valves off. Had the hoses removed overnight and there wasn't any leakage with the valves off. Should I just assume the inlet valve is flaky and needs replacement??
5 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Sep 09, 2007
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Anonymous
  • 351 Answers
  • Posted on Mar 09, 2008
SOURCE: leaking waher
water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: Washing Machine leaks intermittantly
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Anonymous
  • 350 Answers
  • Posted on Jan 20, 2009
SOURCE: Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Anonymous
  • 245 Answers
  • Posted on May 19, 2009
SOURCE: About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
1helpful
Every time I turn the washer off it will keep dripping out of the fill tube at the back of the washer. It will fill the washer tub half full
Hi and welcome to FixYa I am Kelly
Here is what you can do to try and remove the debris from inside the water valve assembly.
-Turn off BOTH wall hose connections
-Remove ONE hose assembly completely and also remove the screen from the hose connection area of the water valve by using a thin knife blade on the outside of the screen
-Leaving the screen removed connect ONE hose to the water valve hand tight and place the free end in a bucket.
-Turn on the remaining wall connection water hose
-Select WARM wash and start washer fill cycle
-Tap on the water valve FILL HOSE fitting for about 20 seconds (Your trying to loosen / remove debris) Do NOT use a hammer.... (Handle ok) but be serious with your tapping.
STOP FILL CYCLE
-Reinstall the removed inlet screen and connect hose to water valve and wall connection.
Repeat procedure for the 2nd hose.
This will clear about 50% of the water fill problems. If it does not cease the dripping while off routine you will have to replace the water valve assembly (Item 17) This link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177917&diagram_id=1341192#d1341192
Detasiled view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4026760
Thanks for choosing FixYa,
Kelly
2answers
At the end of cycle washer will not stop filling and overflows. maytag neptune fav6800aww
There is a diaphram switch located in the machine at the bottom right in the rear. When you remove the front panel it will be all the way back on the right. It senses the water level. It has three levels it detects. I had a problem with mine filling too much. That should take care of your problem.
Maytag MAV6200 will not washer on cold water cycle. Could this be a problem with the push button switch? Washes on all other cycles. However, the warm water is very hot, not warm.
Your cold water inlet valve has more than likely fialed.or.... the inlet screen is completely clogged. First turn off the water to your unit both hot and cold water lines. Then select the wash cycle w
ith hot water only and listen for a hum from the inlet water valve. Then select cold and see if you hear a similar hum. If you do not hear a likewise hum then the cold water solenoid on the water valve has failed and will need to be replaced. (Sometimes this requires the entire water valve be replaced due to the design of the assy) If you hear a similar hum then remove the hoses from the water valve and check for a clogged inlet screen just inside the water hose attachment fitting. If you can not tell if it is clogged remove the screen and hold it up to the light. You should be able to see light through the screen. If it is clogged scrub and wash the screen under running water. It is prety easy to tell if you have it clean. Once you finish reinstall the screen in the water inlet valve, reconnect the hoses and turn on the water. Good luck.
5helpful
2answers
Water continues to drip into the washer when it is finished with cycle and turned off
Water valve is located at the rear of the machine with the water hoses attached to it. Disconnect power. Remove hoses and unscrew the small angled bracket attached to the valve. Replace the valve and your problem will be solved. Part Number is 2200270. This the only possible cause for the symptom you describe.
1helpful
Water drips (tiny drop) slowly from top of washing machine when the machine is off (not from where the water comes from when it is on...but from that same direction). What could be the problem? (Maytag...
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the inlet valve. Make sure they are clear of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sure hope this helps and best wishes.
1helpful
Water continues to drip and fill tub after wash cycle completes
Your water inlet valve where the water supply hooks up to the washer is not sealing good.It can get sediment in it and cause this. Having a well for water supply can cause this more than water that has time to settle.
1helpful
2answers
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
1helpful
2answers
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
1helpful
2answers
Maytag top load washer leak
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
