Vivitar Wireless Remote Shutter Release (VIVRC200XSI) Battery For Canon XSI SLR Digital Camera Logo
Kat Landreth Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to re-sync my Vivitar Remote shutter release RC-200. I'm using it with my Canon 50D. Don't know if that matters. It worked out of the box, but after turning it off and turning it back on, it's stopped working. I suspect I need to re-sync the remote end with the receiver end, but I've lost the instructions on how to do that. Can anyone hep?
  • Anonymous Aug 01, 2012
    I have the same problem using RC-200 on my Nikon 300S. It worked at first then after storing it for about 2 weeks and putting it back on my camera the darn thing didn't work anymore. I re-synced it and it worked again...until I parked it for a while and the same problem occurs. The last attempt of re-syncing it messed up my camera by releasing the shutter on it's own when it's connected to the camera. Needless to say I returned it to Vivitar for service, they acknowledged receipt and even gave me an RMA number and Service number. 3 months had past and i still haven't receive it back! I sent them a nasty email just today. I found this query of yours because I was searching for a review of this product and came across this site.
    Synchronizing the RC-200 is not hard. But keeping it that way after you store it for a while is a challenge. 1.Turn on the receiver by holding down the set/power button for about 3 seconds until the red LED light comes on. 2.Press the set/power button 5 times until the other LED light begins flashing red. 3.Press the shutter button on the transmitter. 5.The flashing red LED light on the receiver will stop flashing and the unit is now sychronized. Good luck!
Catalin Turcu
Level 3:
  • Master 4,924 Answers
  • Posted on Feb 12, 2011
Catalin Turcu
Master
Level 3:
Answers
4924
Questions
0
Helped
1231315
Points
13383
Try this way ...
turn the receiver on ..by pressing the set /power button and hold it until the red light is on ...in this moment if the other button its not on hold it should work ...if not ..it needs pairing (sync) so ..press short on set ..it should blink ..and keep the remote button on until stop blinking or until the second button (for ready to shoot ) comes on ..
I am still researching for this model ..but let me know if it works or not..The idea on all these things when you sync..is to make the receiver search for the source by activating the setting ..than give it a source to recognize by pressing the remote's button ..
it may need to press again the set for to memorize the frequency ..
by the way ..to avoid this for happening I think it needs to be on all the time ...but if it came shut down and worked right the way ..it may be just a matter of turning it on proper...so first keep that set button pressed until the red light is on ..
  • Catalin Turcu
    Catalin Turcu Feb 12, 2011
    by the way ..I'm saying that I don't really think it needs pairing cause it didn't needed when you got it ...so ..unless you pressed something that messed it up ...or you changed one of the batteries ..it may be just a matter of turning it on right .....
    and another thing ...I know for sure that the sync procedure is on the last page of the manual ..I just don't seam to find it anyway ..and working with so many models I might be skipping something ..so ..let me know what you/ve tried and I will guide you on ..
Why does new shutter release not work on canon 50D?
Is this a new installed Canon shutter release? Or are you referring to an aftermarket shutter release you are attaching to your camera?
Aug 16, 2014 • Photography
4answers
Canon RC-1 remote
The Rebel XT must be put in Remote Control mode for it to work:
How do I set up Vivitar remote for Nikon D5300
Set the camera to one of the two remote modes. The quick-response remote mode fires the camera when you press the button. The delayed remote mode gives you two seconds to hide the remote behind your back before firing.
See "Remote Control Photography" beginning on page 70 of the manual: http://download3.nikonimglib.com/archive1/nDjd000XOIQF00mktpj7624w9V96/D5300RM_(En)01.pdf . Just pretend you have the Nikon ML-L3.
Vivitar 285 flash sync for Nikon D5200
What is the exact problem? Is the device not working properly? Did you try to charge it, exchange the battery, test it on a different device? Give us more info.
Nikon D5200 PDF Manual Download
Vivitar RC6 - NIK
You need to set the camera's release mode to one of the available remote modes. As a minimum there should be a remote mode which fires the shutter when you push the button on the remote and a delayed remote mode which gives you two seconds to hide the remote behind your back. Since you neglected to specify the model of your Nikon dSLR I can't tell you exactly how to change the release mode. Refer to your camera's manual, or else reply to this post and specify the model.
3helpful
2answers
Camera settings to shoot the moon
The best way is to set your camera to manual exposure and ignore the camera's light meter. The light meter will try to make the entire scene a middle gray, which will result in a gray sky with a blown-out moon.
There's an old rule-of-thumb called the "Sunny-16 Rule." This says that the proper exposure for a picture under a bright sun is f/16 at a shutter speed of 1/ISO seconds. So if you're shooting a daylight scene at ISO 200 then the proper exposure would be f/16 at 1/200 seconds or equivalent (such as f/11 at 1/400).
Why is this relevant? The moon is simply a large rock essentially at the same distance from the sun as any other landscape you've photographed. So start with f/16 at 1/ISO. Take a look at the result on the back of the camera. The sky will be completely black, but so what? It's the moon you want. Zoom in on it and see whether it looks the way you want it to. Adjust the exposure if necessary. Don't let it blow out to complete white.
I just purchased a Vivitar remote shutter release (wired) & the packaging reports that it fits the Canon 40D. I can't figure out out to insert the device to my camera. Can you help?
If there is telephone support, call them.
Other wise it may be that you have the wrong shutter release.
Your manual may be a help. Read it, for the shutter release.
Hope it works.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
