Question about Samsung PCL6215R 62" Rear Projection Television
Red convergence lines
Red lines appereard on top and bottom. The lettering is distorted. It appears immediatly and then goes away but returns shortly after and stays. Is this a convergence problem?
Thank you,
Bruce
  • Samsung Master
  • 8,617 Answers
Yes, but it sounds like its a solderd related issue because it clears up. Try resoldering the Convergence ICs and if that doesnt help they will need to be replaced.
Posted on Jul 23, 2008
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
Focus problem, see Green and Red misalignment;
this could be caused by the loss of the power to the converge circuit or the failure of the converge chips-stk-xxx-xxx if the problem pops in and out it's a connection problem.
Oct 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Top left and bottom right images/letters distorted.
I can fix it for $325? 213 880 1795
It was a convergence problem, both chips goes bad bad also look for bad resistors around the circuit? This is not an easy repair for non skilled person? You need to realign it after replacing the chips? Don't be cheap pay someone to do it right?
Oct 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Color distortion
There are failures occuring in the scann and convergence circuits. This may not be feasible to service.
Jerry G.
Dec 14, 2007 | Sony KP-43T90 43" Rear Projection...
Thin bright red vertical line from top to bottom of screen
that is the screen burned out. if still have a warranty return to company and get a return/exchange.
Oct 26, 2017 | Sceptre X7G-Naga 17" LCD Monitor
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Samsung PCL6215R 62" Rear Projection Television Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
