I have a Pinguno PAC190 with an Fe error. I drain the water out of it. (about 1000 cc or more). It starts up but within 3 hours enough accumulates to turn it off and come up with the error. Any suggestions?
  • 143 Answers
Air conditioners should not accumulate water and shut themselves off. You need to repair the drain.
Posted on Jul 25, 2008
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
I have LG WM2487H*M and at begining of wash cycle when the water is filling, the FE code comes on and it keeps filling with water then drains the water when it reaches a level. What is wrong? I then shut...
Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically
LG WM2487HM series Service Manual Error Display
Oct 26, 2017 | LG WM2487HA Washer
Machine sticks and 'timer saver' flashes. When turned off and onto 'drain' the lights shown on the video flash.
Switch off machine for an hour, press down all the panel buttons to drain any residual voltage to the board. Now when the power is reconnected and the machine is switched on, press down Start/Stop/Pause buttons.
If the fault does not clear, then check for dirt in the inlet and outlet , check flow and drain without water accumulating within. If not the control board is a suspect
Jan 04, 2013 | Washing Machines
The water in the tub is draining out on its own and the led indicator shows FE
The FE error code indicates water is overflowing due to the faulty water valve. So, the 4-way water valve will need to be replaced.
Here is the part you need.
Oct 20, 2012 | Washing Machines
I have a 50 gallon Richmond Power vent water heater. The burner would try to light but would not. I replaced the vacuum switch, but this did not solve the issue. The tygon tube that runs from the vacuum...
The accumulation of condensation in the vent piping is more than likly the problem. I am guessing the vent piping is either 3-inch or 2-inch. You need to splice in a "T" fitting reduced down to 3/4-inch with a 3/4-inch tubing attached and run this to a sutible drain. This will drain the condensation elimiating the accumulation in the vent assembly. Install this "T" fitting about 3-feet down stream from the vent motor.These supples and fittings can be found at a Home Depot or Lowes store.
Jan 27, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Hi I hav a toploader and misplaced my Manuel I need a list of the codes the machine gives if it has a problem so I can fix it! Thanks
IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on. "UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight "OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge "FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. "PE" Pressure sensor error. Cause: the sensor switch assembly is out of order. "dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming "[-E" Heating error. Cause: the thermistor is out of order. CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited. LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective. bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode. EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. PF Power failure. Cause : the washer experienced a power failure. E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | LG Washing Machines
Hi my washer dryer 9kg front loader wd 1290 rd is showing a code d.h.e in the middle of drying?
here is a list of eror codes i dont think your reading what yours says correctly hope this helps
"IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on. "UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight "OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge "FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. "PE" Pressure sensor error. Cause: the sensor switch assembly is out of order. "dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming "[-E" Heating error. Cause: the thermistor is out of order. CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited. LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective. bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode. EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. PF Power failure. Cause : the washer experienced a power failure. E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Aug 11, 2010 | LG Washing Machines
How do I clear error code LE? I do not want to call for service.
LG
Washer Fault Codes Failure Code Condition Check/Repair "IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on. "UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight "OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge "FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. "PE" Pressure sensor error. Cause: the sensor switch assembly is out of order. "dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming "[-E" Heating error. Cause: the thermistor is out of order. CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited. LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective. bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode. EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. PF Power failure. Cause : the washer experienced a power failure. E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages. Return to top
MAYTAG
Stackable A/W and Dryer Fault
Dec 02, 2009 | LG WM-2277HW Front Load Washer
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
